So it started out with buying blue replacment LED's for the clusters from 666DAN... but my climate controll lights didnt work, i honestly didnt even know if they were meant to have lights..
took it all appart to find that i had everything needed to turn the existing blown bulbs into blue LED's laying about in my workshop...
Looks SWEET now, gonna have a go at getting the LCD backlight blue tomorrow maybe...
I was also thinking about mounting 2 blue LED's inside the air vents so small amounts of blue light comes out of the vents... But on the other hand... That might be too much blue, As the new sterio is gonna be blue theamed aswell.
If i decide to do the Air vent LED's does anyone know the easiest spot to tap into the light circuit?
https://www.sau.com.au/forums/topic/271100-r34-gtt-dash-lights/
Thats sick! I really want to get mine done, but I've run into so much trouble with it. My last attempt killed one of the LED's. Couldn't find a replacement, so got a whole AC unit replaced.
My original unit was from a series 2 so it had different lights.. now I'm not even sure what LED globes I need from Dan666..... *sigh*
you need to place a resistor in series with the LED to limit the current, other wise it basically shorts out the unit.
i used 2* 180 ohm resistors giving 360ohm total that limited the current to around 25mA whish is the value that these specific LED's create the maximum light output
Slightly off topic but does anyone know how to even out the bright vs dull spots on the dash? I too have recently fitted white multi-angle LED's (from 666DAN) to my R34GTR.
Don't think it's possible man. I've got this kit of 666DAN also and it's the best it can be afaik. I think red LED's make it perfect but.
Here is my setup... I've changed the double DIN HU to Snigle and put a consult display unit underneath.
  • 4 weeks later...
  • 11 months later...
very nice.... i like it..
You can never have too much blue lol i can barely see out my windscreen at night so many cobalt guages in my face, lol looks maad but i think a lower voltage transformer or somethin might be in order....
Looks cool man.
  • 4 weeks later...
That looks really sick mate. To bad I can't make mine Blue I'm force to do it red. Main reason is the R34 GT T series II has a film over the dash so on well I am happy for you. It turn out really nice and sick :D . Think of blue neon above the pedals and under seat as well.
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
