So it started out with buying blue replacment LED's for the clusters from 666DAN... but my climate controll lights didnt work, i honestly didnt even know if they were meant to have lights..
took it all appart to find that i had everything needed to turn the existing blown bulbs into blue LED's laying about in my workshop...
Looks SWEET now, gonna have a go at getting the LCD backlight blue tomorrow maybe...
I was also thinking about mounting 2 blue LED's inside the air vents so small amounts of blue light comes out of the vents... But on the other hand... That might be too much blue, As the new sterio is gonna be blue theamed aswell.
If i decide to do the Air vent LED's does anyone know the easiest spot to tap into the light circuit?
https://www.sau.com.au/forums/topic/271100-r34-gtt-dash-lights/
Thats sick! I really want to get mine done, but I've run into so much trouble with it. My last attempt killed one of the LED's. Couldn't find a replacement, so got a whole AC unit replaced.
My original unit was from a series 2 so it had different lights.. now I'm not even sure what LED globes I need from Dan666..... *sigh*
you need to place a resistor in series with the LED to limit the current, other wise it basically shorts out the unit.
i used 2* 180 ohm resistors giving 360ohm total that limited the current to around 25mA whish is the value that these specific LED's create the maximum light output
Slightly off topic but does anyone know how to even out the bright vs dull spots on the dash? I too have recently fitted white multi-angle LED's (from 666DAN) to my R34GTR.
Don't think it's possible man. I've got this kit of 666DAN also and it's the best it can be afaik. I think red LED's make it perfect but.
Here is my setup... I've changed the double DIN HU to Snigle and put a consult display unit underneath.
  • 4 weeks later...
  • 11 months later...
very nice.... i like it..
You can never have too much blue lol i can barely see out my windscreen at night so many cobalt guages in my face, lol looks maad but i think a lower voltage transformer or somethin might be in order....
Looks cool man.
  • 4 weeks later...
That looks really sick mate. To bad I can't make mine Blue I'm force to do it red. Main reason is the R34 GT T series II has a film over the dash so on well I am happy for you. It turn out really nice and sick :D . Think of blue neon above the pedals and under seat as well.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
