hey guys getting a new turbo this sat so selling my r33 turbo series 2.
really good turbo for a rb20 or replacemnet for your rb25.
no shaft play, on car now if you wann see it running only tomoro too see it.
has elbow, 33 actuator, bolts if needed, lines if needed for extra $$$$.
i also have a remapped dr drift ecu to suit r33 turbo, full exhaust, fuel pump,.all you need is a tune from dr drift at your looking at 190kw
both items for $600
or offers for each pm me guys iam i n vic i can post anywhere.
both items for $600
hey cant pm how much for just the turbo?
Hey im from Canada and looking for a turbo local but its not working out. Would there be a chance you would ship to Alberta Canada, Postal Code is T0M-0J0 and im in Blackfalds Alberta.
Thanks for any help. would only need the turbo.
PS. any idea if there are any differences between a series 1 and 2, as far as the oil/coolant line go? I have a blown series 1 right now that i want to replace quick and easy..
[email protected] or PM
Kyle
Kyle
no way man i dont even know how to post to canada..ill ask the post office tommoro. will let you know
hey mate. Any pics of turbo? kms? how much to post to 4814?
does not come with the hks actuator or the dump pipe
it came off a 100k car and on my car for 3,000km great turbo you wont have a problem
post shouldn't be too much iam guessing $25
Edited by R32 DRFT4
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
