This is a limited time offer to all members of SAU from the kind people at SAU:NSW and Federal Tyres :)
ALL THAT'S LEFT GUYS! This will run for another two weeks (so until the 7th of December) then it will be closed and gone :)
SAU:NSW and Federal tyres thank you for looking and hope that anyone who bought the tyres enjoys them! :)
1 x 195/50R15 595RS - $90.00
1 x 225/45R17 595RS - $90.00
1 x 255/35R18 595RS - $90.00
Freight charge on the above tyres = $11.00 (anywhere in Aus).
This is the CHEAPEST price ever offered on these tyres and is valid only while stocks last.
To order your tyres, send me a PM using the following outlay:
--Personal Info-- *Necessary info
Name*:
Forum Name*:
Post Code*:
Email:
Phone Number:
Shipping Address: (this will be necessary after payment, but not for a quote)
--Tyre Info--
Width*: example 255, 265 etc
Height*: 30, 35, 40 etc
Rim Size*: 17, 18 etc
Amount*: 2, 4 etc
Deposit the money into this account, MAKE SURE TO USE YOUR FORUM USERNAME ON THE DESCRIPTION. I want to keep this as tidy as possible :)
Account Details
Bank: CBA
Acct Name: Steven Hill
BSB: 06 2121
Acct No.: 1012 2011
Also, remember that this is FIRST IN FIRST SERVED!
https://www.sau.com.au/forums/topic/271212-federal-semi-slick-tyres/
  • Replies 107
Here is an honest review of them from Abo-bob, the SAU:NSW President:
On a personal note, I used these on the front of my car at the last SAU track day. I had RE55's on the rear which are some of the best semi slicks there are. IMO, the Federals were half way between street tyres and the RE55's. They gripped well but were outgripped by the RE55's. The thing that made them so good though, was that after a full day out on the track, they barely look used at all. I am intending to put these on all 4 and use them on the street as well because I'm lazy and don't want to change wheels all the time.
The other thing I noticed was that the Federals warmed up in the first lap but the RE55's took about a lap and a half. Neither went greasy despite many laps. Street tyres will do this though. So you can do heaps of laps in them and quick warm up means they may be good for hillclimbs perhaps and other disciplines where there isn't much time to warm the tyres.
I guess my point here is that they are not the most grippy semi slicks around, but they are better than streeters and as a value for money proposition, they are outstanding.
Suitable for the drags yes (not as much as actual drag tyres like Mickey T's though)
Daily driver? Not so much. They will be very slippery in the wet and will wear down a little bit quicker then your standard tyre. EDIT: Apparently not as bad as I thought, read down.
I know people, one R34 GTR Nur spec in particular, that runs semis all the time and is daily driven. His choice of tyre is Federal as well :P
I know people, one R34 GTR Nur spec in particular, that runs semis all the time and is daily driven. His choice of tyre is Federal as well :)
Hey Steve,
I just thought that I would try to help out by adding in my two cents :D
I have been using 595RS' for a few years now on my R32 (daily drive) and have found them to be pretty good in the wet (considering that they are a semi-slick)... As long as you remember that they are more meant for dry road use and dont mash the loud pedal to much, you shouldnt have any surprises in the wet... Motor magazine rated these the "Best wet braking" semi slick in their last tyre test.
Also, my last set of these lasted a touch over 27,000kms so you can get pretty good life out of them if you keep up regular tyre maintenance.
If you are after a great all round performance tyre these are the pick of the bunch for "bang for your buck". :(
Just so everyone knows, the tyres listed are the only ones being offered at this price to anyone on SAU.
SAU:NSW has an exclusive deal with Federal tyres for its members allowing them good prices on any size tyre.
I have these on my r32 daily driver and they are good. the wear is fine, not as good as a street tyre but i have done a few 1000 k's and they are still line new. and they are fine in the wet.
I would like a set but is pickup possible? I am not home during the day for deliveries which makes it hard for me.
No sorry, no chance for pickup. You could always send them to a mate who CAN receive them, perhaps someone's office or something?
These are selling like hotcakes guys, you won't EVER beat this price again, I suggest you get in NOW! :D
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
