OK friends, to prove how much these guys want these tyres gone, for every person that buys 2 or more tyres, your name will be entered into a raffle between all the other purchases from this GB ONLY, so VERY good chances of winning!
The prizes are as follows:
A Federal Motorsports Jacket worth $80!
And a Federal Motorsports Cap worth another $20!
Raffle will be drawn at the end of June.
And to those people that have already purchased tyres don't worry, your names are already in the raffle ;)
Remember, you WILL NOT find BRAND NEW, UN-USED SEMI SLICKS straight from the supplier to your door for this price for a VERY long time to come, if ever!
  • Replies 107
Anyone know what these are like as a daily driver on the road and also if they are suitable for the drags?
I drive my Skyline every day and at the moment I am running Federal 595RS-Rs (the successor of the 595RS semi) on the street. With the recent rain here I can honestly say that they are much the same as a street tyre when it comes to the wet, if not slightly better. :ninja:
dooooof. 265/35/18's
caarn man, you can do it
You're right, I can... FOR CLUB MEMBERS ONLY TONY! :rofl2:
when I've joined your club lol you got these in stock... 255/35/R18?? want 4 <<<do i get 2 raffle tickets :D
Yeah they will be in stock, but they won't be this price, and no, no raffle tickets... well, I might be able to squeeze you in :sick:
i gotta say this is damn cheap for a damn good tyre! Ive had these on my car for 6months now and they are among some of the best tyres ive driven on wet and dry!
Ive never had this much confidence in any car in the wet before
What would be the best for 17x8 for front and 17X9, not looking for super low profile.
Ideal fitment would be 235/45R17 front and 255/40R17 rear if you are after maximum traction, but you can vary anywhere between 215 - 235 on the front and 225 - 255 on the rear safely (depending on the tyre)...
It depends on what type of driving you are planning on doing.
i put the 235/45's on my 17x8's. whats the ideal hot temp for these? i was trying to keep em around 40psi on the track as i wasnt sure how
hard the sidewall on these are?
what would it be for 2 255/40R17 and 2 235/40R17 posted to QLD sunshine coast
It would be $420 as we are not offering 255s, only the 235s are available.
:sick:
Ideal track pressures would be about 34 - 36psi cold as they will pick up around 6 - 8 psi when hot... I have found that ideal temp for track use is between 60 - 80 degrees on the tread face.
The sidewalls in the 595RS are fairly strong but when used on the track they can fold under a bit, keep checking the sidewalls for signs of wear and adjust your pressures to suit. :sick:
OK fellas, as was promised, the prize draw for the jacket and hat has been done, and the winner is...
*DRUM ROLL*
ssxRicho!
A PM has been sent for an address and what size jacket you want :sick: Congrats!
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
