Just installed the Ecliptech Shift-i sequential shift light.
Very easy install.
These are the wiring points i used on the back of the cluster.
Red= +12v Ignition
Black= Ground
Blue= Tacho signal
I used the wire clips that came with the light to splice into the
back of the cluster. The factory Tacho signal wire is Yellow with Blue tracer.
Green wire for 12v Ignition.
And the ground point as marked on the first image.
I tested it at this point by turning on ignition.
Then put dash back together.
Just used trusty old double sided tape to secure it.
Only needed to calibrate up one point and it's spot on.
Cheers
  • Like 1
https://www.sau.com.au/forums/topic/271246-installing-ecliptech-shift-i/
  • 1 year later...
someone correct me if i'am wrong but the rpm signal coming from the ecu pin 7 (yellow with blue stripe) is only a 5-7v square wave and isnt enough to power my drift digital rpm gauge there is power feeding through it but when connected to pin 7 and once the car is started no rpm reading so i had to go out and purchase a bloody vdo signal amplifier so i can run my aftermarket digital tacho :thanks:
any enlightenment would be appreciated
  • 3 weeks later...
someone correct me if i'am wrong but the rpm signal coming from the ecu pin 7 (yellow with blue stripe) is only a 5-7v square wave and isnt enough to power my drift digital rpm gauge there is power feeding through it but when connected to pin 7 and once the car is started no rpm reading so i had to go out and purchase a bloody vdo signal amplifier so i can run my aftermarket digital tacho ;)
I suggest emailing Tony (the maker of shift-i) and asking him.
The guys is one of the cleverest people I've ever come across.
He'll no doubt be able to answer your question.
ive bought this last year and am very happy with its performance. love how theres so many functions on just 2 buttons tho it was confusing at first and you'll lose your settings if you replace your battery. ive spliced my signal wire on my ecu's tacho signal wire
  • 3 years later...
Hi all, I bought a shift light for my r32 gtst, wired in 12v pos earth an pin 7 tacho speed signal (yellow/red) and I cant get the thing to work. Its been extremely frustrating
I have also tried wiring it to the cas and timing loop
Does anyone know how I can make it work?
its a regular shift light, pos neg tach signal cut brown loop for 6cyl etc
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
