Lithium, I also was hoping for full boost earlier, It may be the stock manifold holding it back or the lack of timing coming onto boost. its a fairly conservative tune. and if a 3582 is a 3540 with a .82 rear housing then you'd be very close.
I think with a better manifold design and some more tuning time you would get it coming on quicker.
I am still happy with it!
Oh yeah not knocking it, its a good result and I can imagine is a monster on the street. I have been keeping an eye out for Holsets results as many people claims for them seem almost too good to be true - I only said that to get your feeling on it. It is pretty much what I would expect a good and reasonable sized plain bearing turbo to do, which means its not magic but it represents good value for money which is how I have suspected Holsets really are.
A "GT3582R" is a "GT3540R", Garrett changed their naming convention a few years ago. The 82 bit refers to the mm size of the compressor exducer, not turbine a/r :) My car is running a .82a/r GT3076R on a stock RB25 with a stock log manifold and I had a few dyno runs this weekend to sort out boost control and had it hit 19psi by 3700rpm in one run where the "gain" was set higher than needed!
Edited by Lithium
yep I remember reading you were going to get one and low mount it ages ago :) what sort of power is the 3076r making on your 25 at 19 psi?
I am not running 19psi, that was just a booboo while refining my boost control - I have made posts in the past on my dramas trying to get the boost control sorted out. It made 284rwkw this weekend with boost varying between 15-17psi :)
When it spiked to 19.9psi it hit 180rwkw by 3700rpm!!!!!
man i cant wait to put mine on. Had mine for over a year just waiting on money for the supporting mods...I would put money on it that the 20mm spacer,stock manifold, and turbo wont fit on my left hand drive 180sx
cheers
hey Demetrius,
do some googling, there are a few 240sx's in the us running holsets on ka24's and rb20's they should be able to help with mounting advice.
I think I have worked out how to bring spool on a LOT faster
more updates soon
Well I decided I would put it on the dyno this afternoon for a quick check to see if it would be ok to drive it like it is untill I get it properly tuned with the bigger injectors and afm...
1st run - 10psi all good, very rich (9.8:1)and pulled a lazy 246rwkw
2nd run - 15 psi I was a bit nervous and did not mean to up the boost that much! 288rwkw WTF!!! jeebus! this was my power goal
3rd run - 17 psi too lean (12.7:1) just after peak torque and it spiked sharply so boost control needs to be sorted out but it pulled 311rwkw
no wonder it felt fast...
You should have seen heard the amount of exhaust gas flow on the 3rd run it sounded like a big dirty jet!!
boost comes on progressive and hits 17 psi at 3400 rpm but it feels like its on full boost from about 3000.
I suspect even more boost will nett no more gain due to the stock manifold. and i don't want any more power than this. I drove it down the road just after the last run on the same boost and it was to brutal... absolutely brutal...
so I will swap in the bigger injectors and tidy up the tune as the current fuel curve looks like a stock market chart. also there is a fairly big hole in the midrange due to the timing map needing to be totally redone but the turbo has prooved itself...
I suspect the turbo I have needs the oil seals done, either that or the oil drain is not big enough for the turbo as its smoky on start up and occasionally when you back off after full boost. but a turbo repair kit for one of these is only $100 :)
the dyno sheet was BUTT UGLY due to the afr's and timing map so i didn't bother with it but the numbers are great! the dyno operator was fkn impressed, he looked under the bonnet and shook his head and said " looks like stock, goes like a velvet sledgehammer"
I had a laugh and decided I would call it just that
"the velvet sledgehammer" Wooo Hooo!!!
Did you have any boost controller when you ran it with the internal wastegate? i was thinking of porting the internal wastegate and use an electronic boost controller hoping that i wont see much boost creep. im planning to run 15-20ish psi, what ever our crappy california 91 octane can handle. let me know what you think.
on the internal gate I was using a turbotech boost controller and it would hold boost fine in low gears and low load. as soon as you accellerated hard in 4th up a hill boost would keep climbing and i did not want to find out when it would stop.
if you ported the buggery out of the internal flap and used a decent ebc you "might" be able to get away with it, it depends on the amount of gas your engine will produce. i would have less chance with the 3ltr that someone with the rb20 would.
this turbo is really designed to run high boost so if all you are aming for is 15psi you might be better suited to another turbo.
were you using the holset wastegate actuator? how did you get your boost to go that low? i thought hx wastegates were set at 20+ psi?
i have no issue running it in the 20+psi because i have all the supporting mods i just wanted to start in a lower pressure for tuning purposes, i didnt want to start tuning at 20+psi.
just a heads up for anyone looking for one of these...
THIS IS THE EXACT same turbo as the one making over 300rwkw on my car for sale on ebay.
good cheap turbo capable of 350rwkw!
  • 5 months later...
hey guys im just doing a hx35w swap on my rb25det. i just need to know how you guys are running the oil return lines what kinds of hoses and fitting and placement. im running a 4an steelbraided line for the feed and local shops in alberta are saying they can make me a line for the return.
Also what is the simplest / cheapest way to make the dump pipe for for the turbo. Thanks
  • 7 months later...
  • 11 years later...
Curious as to whether Cef's car is still alive and running this setup? Anyone else bolted an HX35 on an RB20 with similar results? I always thought the factory manifold is a twin scroll by design so pairing it with a twin scroll turbo is a no-brainer.
Do you really want to wait until 6500 rpm for boost? Big turbo, small engine, no fun.
On my rb20 sohc (so worse flowing than dohc heads), I had HX35 with smaller 50mm 7 blade compressor inducer and 0.82 a/r t3 twin scroll Garrett turbine housing on a twin scroll single wastegate exhaust manifold with proper divider wall up to the wastegate. On 95 octane gas at 4th gear it started spooling around 3500 rpm and reach 15 psi around 4200 rpm. Change only the hot side to smaller hx30 52 mm turbine with t3 twin scroll 12cm housing, also on 95 octane gas at 4th gear it starts spooling around 2800 rpm and reach 15 psi around 3500 rpm with good transient response, still on my car after 5 years. HX35 with the usual 54mm 7 blade compressor inducer which compressor map flows around 55 lb/min and  should spool about 300 rpm slower.
Yes, i agree that rb20det/rb25det factory manifold modified to twin scroll with 25-30mm spacer plate to pair it with a t3 twin scroll turbo is a simple, cheap and effective set up if target hp is within flow limit of factory manifold. You can weld the wastegate pipe to the manifold or mill waste gate ports to the spacer plate then weld the wastegate pipe to the ports on the spacer plate.
Spacer wastegated.jfif
  • Like 1
Perfect response! This is exactly what I was looking for; actual real world experience and data. I'm going to be keeping the Torque valve as well as swirl valves on my DE Neo as well as variable intake, so that would no doubt help with spool up immensely. I am already set on the HX twin scroll series turbo, but if I can get my hands on both a 30 and 35 to make a hybrid like you did, I might do that. Power is not really my goal as much as just making this 20 feel on par if not slightly peppier than a stock 25DET.
I looked at that gated spacer and honestly I've never seen one like that but it looks genius. However I'm worried about potential boost creep? Those ports are not only small but they exit at 90 degrees to the exhaust flow, which is usually not optimal. Also what about the little slot in the stock manifold opening at the divider? Did you weld that up then grind flush or did you leave it be? I'm unsure why Nissan left it slotted like that but I would imagine it's to account for thermal expansion and to help with channeling the gasses downwards?
Leave it. Anything you weld there is going to be so dinky that it has a better chance of falling off at some point and killing the turbine than being useful.
Because Nissan were using open turbine housings. There wasn't a lot of point in trying to have a perfect divider.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
