Hey,
Just wondering if anyone has ever tried to put an rb26 gearbox into an r32 with an rb25. Reason for wanting to do so is, i have a stock rb20det gearbox in there atm and its not going to hold up the power its making. RB26 gearboxes are heeps cheaper than rb25 and I can modify it myself to RWD, i have done one before for a silvia conversion.
Just wondering if anyone knows where or not the gtr32 cross member will bolt straight up, and whether or not anyone knows for sure if rb26 gearboxes are stronger than rb25 ones? Also would a RB25 Nismo slave fit onto a RB26 box? Im assuming that all RB gearboxes have the same 2 bolt pattern
thanks for any help
https://www.sau.com.au/forums/topic/271700-rb26-gearbox-into-rb25-r32-gtst/
anyone?? Im gonna buy an RB26 gearbox and just give it a shot. Damm well hope it works. But some info first would be great if anyone knows anything
A full write up/tutorial on the modifications to gearbox would be awesome...please.
Only problem with a 26 box instead of a 25 one is that you know that the 26 will have copped a lot more abuse over its lifetime..
thats BS and means nothing....
if you gonna say that then you could say a GTR box will have been serviced better.
to be honest i think GTST's are driven harder than GTR's....
hmm. So you are trying to tell me that every japanese gtr owner actually serviced their gearbox, ever.. or gave a crap. Let alone factor in the added power and torque on the mechanical workings and the added load on the output of the 4wd system..
hell no.
but you were trying to tell me that no GTST owners thrash their cars!
i see where your coming from but there's way too many variables to be able to say that GTR boxes will be in a worse condition.
Hey,
thanks for any help
chur i put a r32 gtr box in my cefiro but i didnt cut the transfer case off so had to cut a hole in the gearbox tunnel for that the crossmember doesnt fit i got a custom made 1 and yea the slave is the same i used my 20de slave on mine abit of a tight fit but it does would of fit straight in if it wasnt for dat transfer case
you cut up your car befor the gearbox lol, your mad. Im hoping the crossmember will fit because its from a r32. I will post progress pics when i recieve the gearbox, just after the damn freight company stops stuffing around the little fella!!
i reckon everything will bolt up except the crossmember. i've just done my clutch yesterday and contemplated the same change your talking about - but i reckon it's risky. even though 26 box's are cheaper then 25's it's still a fair bit of money to risk buying then finding you need to mod your crossmember.
  • 8 years later...
hi good day guys. im currently doing this said conversion on a nissan c33, i got the shaft done yesterday but my problem is the bracket itself is too low for the car. i really dont want to cut my car to send the box higher is their any other options? the box works perfect and the ratio is heavenly just i can barely drive the car would some coilovers help?
This post suffers from not being at all clear what the problem is.  How would coilovers solve anything to do with how the gearbox sits in relation to the rest of the car?  And more importantly, what bracket are you talking about?  The gearbox crossmember or the centre bearing mount, or what?
  • 3 weeks later...
The gearbox cross member
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
