i can allready tell this topic will be a hecktic one lol
but i read in a magazine (HPI) that by removing the mesh that is apparently ment to "smoothen out the flow" of the air going in will actualy give you 11% more flow with out them... they said there there mainly to stop the whetston bridge? (afm sensor) getting KO'd by random stuff if your pod falls off?? worth while to try im thinking just wanted to see what all you dudes thaught :D cheers.
  • Replies 51
I always go by the rule that the factory put it there for a reason.
Also ... how much of that (claimed) 11% increase will you gain depending on what filter you run?
Seems like a too greater risk to me, for such a (realistically) small gain. I doubt you'd notice any gain.
Any other thoughts? :D
umm i would rather keep the mesh and not have the extra 11% flow and keep everything safe in the line Adam
but then again chances of that falling is pretty much none so would be worth giving it a go
Nissan put the turbo, boost solenoid, exhaust and suspension there for a reason too, why did you upgrade?
:D
they mightve put em there for a reason, but that doesnt mean those parts didnt suck. :D
ps, ill be buying some donuts from you me thinks.
Edited by scandyflick
they were following certain neccessary things in building a new car, you cant roll a car off the production line with 95db exhaust systems and rock hard coil overs
however im sure they dont say, hey i know a way we can make this car go slower for no apparent reason
:D
They're not sensitve to particles in the air :dry:
(turbo 'maybe' if you run no pod and drive thru sand storm)
Ouch! Why all the blue mesh hate :P
Edited by RubyRS4
The reason there is mesh in an afm is to keep the air flow at a consistent speed. If you remove the mesh you can get turbulence in certain portions of the cross section while the air starts circling around the inside of the tube, and that in turn gives your AFM an incorrect reading - yes you can force more air thru the tube if you remove the mesh but the electronics wont actually read it consistently because the sensor is in the middle of the tube - turbulence could put a dead spot in that very section (like the eye of a tornado)
-D
-D
And there you have it
[end thread]
:dry:
....circling around the inside of the tube, and that in turn gives your AFM an incorrect reading - yes you can force more air thru the tube if you remove the mesh but the electronics wont actually read it consistently because the sensor is in the middle of the tube - turbulence could put a dead spot in that very section (like the eye of a tornado)
TURBULANCE IN A TURBO wouldnt that make it go faster? twin turbulance super mod :dry:
Edited by Inline 6
i did this about 8 years ago in my 33 you can see a slight difference on the dyno n gained 4rwkw if i remember
yes it was a before and after thing and with no filter i gained like 8rwkw
if you have a decent filter on its a ok and free upgrade, tune does help it along also
but.. what does 11% flow equate to? ..2% increase in kws, 10kph increase in top speed, less turbo lag??
IMO prob only slightly faster spool up. Turbo size and filter used already determines volume of air. It would only have a small effect outside the effects of turbo and filter. I reckon its just spools up marginally quicker, but you'd wouldn't know it.
Anybody got any "on paper" testing/documentation?
Edited by RubyRS4
maybe replace it with blue mesh, it will get 11% for sure then
dont remove it.. unless you want to destroy the tiny ass hot wire on the sensor ....not worth it for 11% gain in seat of the pants take your spare out and stereo
Edited by sapphiregraphics
yeah if u wanna go faster, follow my dads advice "Eat Less Kebabs"
Truer words ne'er spoken.
-D
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
