I am trying to get hold of an M35 ECU (VQ25DET) for a test remap to be done on it.
If anyone know's of a wrecker's anywhere in Australia that has an M35 on it's inventory please let me know.
https://www.sau.com.au/forums/topic/272158-wreckers-with-an-m35/
  • Replies 111
Posted Images
No good, I just rang and they only have parts which unfortunately in this case does not include the ECU.
Nice try though!
Can you also please ask the guy you know if they willing to sell the factory screen?
As I want to do some project on mine!
Yeah, there's lots more involved, unfortunately...
Oh, do you know about the Stagea meeting we are having here in Sydney in just over a week? Details are here: http://www.skylinesaustralia.com/forums/Ns...rs-t266253.html
theres a LOT more to it that that. I do ahave a full set up here that I wish to move on. contact for more details :D
Hi chris,
how much do u want for it?
please PM me with ur email so i can contact u direct as I can not PM anyone at the moment.
Yea Look like i will be going to the meet!
Hey Guys,
I have my brother in Brisbane working on finding a donor ecu, he said he should be able to find one with out a problem..
but i think its slim since not even yahoo japan has them :)
You could always buy the KS ROM for VQ25DET, use it with some octane booster and donate your ecu....
..... or not.
Have sent a few emails out to used parts importers i know of... see how i go
Thanks man, your assistance is appreciated.
Has anyone tried SSSautomotive yet?
Not yet, I've just looked them up, going to give them a buzz in a few minutes.
Thanks again Teren ;)
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
