what are legal positions for front number plate? after getting my car resprayed i want to mount front number plate on the side but dont know which side?
i already had cops trying to defect me for number plate angle and only 2 screws coz they couldnt find anything else, so i wanna be sure before i drill any holes in freshly sprayed front bar.
https://www.sau.com.au/forums/topic/272186-number-plate-position/
i dunno whats legal but i have mine mounted on the left and ive had many cops look at my car and not say anything about it :rofl:
i think its got to be about 100mm off the ground to be legal or something , might have to call regency up mate
passenger side. only reason i chose that side is a lot of cars that come from the factory with offset plates, have em on that side (ie alpha romeo).
dont think they are to fussed on which side they are on. but it would make sense to have them on the drives side though, that way on-coming traffic can see it with ease
OK..
i was pulled up by a cop at a car park on one of kell's cruises,
i had it on the passenger side, right down the bottom of the bar.
she didnt mind it being on the side, or on an angle, but said it had to be ATLEAST 30cm off the ground.
first hand info right there.
I'm not sure about the ruling in SA, but in Vic it must be legible when viewed from a 45-degree angle from either side of the car.
Its about 20 degrees maximum in the official transport SA guidelines but like craig said, they're more concerned about visibility and height - I've never had any issues with my plate, it went thru regency fine with the relocation kit and that has around a 10 degree angle
-D
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
