what are legal positions for front number plate? after getting my car resprayed i want to mount front number plate on the side but dont know which side?
i already had cops trying to defect me for number plate angle and only 2 screws coz they couldnt find anything else, so i wanna be sure before i drill any holes in freshly sprayed front bar.
https://www.sau.com.au/forums/topic/272186-number-plate-position/
i dunno whats legal but i have mine mounted on the left and ive had many cops look at my car and not say anything about it :rofl:
i think its got to be about 100mm off the ground to be legal or something , might have to call regency up mate
passenger side. only reason i chose that side is a lot of cars that come from the factory with offset plates, have em on that side (ie alpha romeo).
dont think they are to fussed on which side they are on. but it would make sense to have them on the drives side though, that way on-coming traffic can see it with ease
OK..
i was pulled up by a cop at a car park on one of kell's cruises,
i had it on the passenger side, right down the bottom of the bar.
she didnt mind it being on the side, or on an angle, but said it had to be ATLEAST 30cm off the ground.
first hand info right there.
I'm not sure about the ruling in SA, but in Vic it must be legible when viewed from a 45-degree angle from either side of the car.
Its about 20 degrees maximum in the official transport SA guidelines but like craig said, they're more concerned about visibility and height - I've never had any issues with my plate, it went thru regency fine with the relocation kit and that has around a 10 degree angle
-D
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
