As the title states, my wife just rang and she got busted twice by a fixed camera for speeding within ten minutes of each other (South Australia obviously). The first one she said she was doing roughly 10km over the limit (in a 50 zone) and the second one she was doing roughly 20km over the limit (again in a 50 zone). How much of a fine can she expect for this breach of the law?
I need to budget for it :)
Cheers
  • Replies 86
expect anywhere from around $400 up to $700 mate.....how unlucky getting done twice in 10 minutes.....but thats the price you pay for speeding....unfortunate but its the law...so yeah expect a hefty one coming soon in your mailbox mate...there will also be a big dent in the demerit points for her
goodluck and hope its a small amount
its about $204 for 60 in a 50 zone that again for 20kph over but also add another 80$ my guestinateguestimate is $488. Personally i would take her keys off her :)
yeah just over a year ago mine was 57 in a 50, $197 from memory.
its about $204 for 60 in a 50 zone that again for 20kph over but also add another 80$ my guestinateguestimate is $488. Personally i would take her keys off her :P
Isnt it 15k over the 1st bracket pretty sure you in new territory with the 2nd fine.
hold on let me get this straight, she gets done by 1 and then speeds up more ;)
i recommend getting her a car with a low rear license plate and a tow bar :)
i just paid 201 bucks for a speed camera fine i was 10 ks over this was only a few weeks ago .
i was rushing the dog to the vet after he ate ratsack . so im happy the wear that one dog made a full recovery im pleased to say
my piece of paper says $290 + $20 levy and that was for in a 50 zone
but no one knows the speed , fine says "exceed speed in built up area" and that was from a patrol car , not a camera ;)
my mate got done twice in 10 minutes 6 months ago and lost his license cause he was on his P's
lol see this is what i find funny. All they bang on about is speed kills yet everyone in this thread has exceeded the speed limit and is still alive...
10 - 20 k's tom3h? more like 170 km over the limit.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
