She can go get f**ked lol. I can't even stand people leaning on my car let alone sitting on top of my AFM's.
I had Rach, obviously a chick, sitting on top in the middle of the bonnet of the GTR the other day when I walked outside. I went nuts! Told her to get the f**k off the thing. She's all like "are you trying to say I'm heavy now?"
Can't win with women.
Funny story... the girl sitting on that R32 GTR happens to own an R32 GTR...
Also, is that 33 up there built by birrong automotive? It looks familiar :happy:
490awkw @ 23psi pump fuel with a gt40?
Still fap worthy even if it had datsun 180b seats. :)
All that money spent and its rolling on bob jane ROH wheels. They don't even look the same size all round (plenty of dish on rear and nothing on the front)
seen this a lot. seems pretty common to me
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
