Who says 2.5 tonne yank tanks don't fly?
Anything can fly if you hit a ramp hard enough ... I'd like the see it handle the 'Ring though. $20 says it couldn't do a sub-11 min lap without breaking something.
This is a factory "Baja Rally" special edition, $15K worth of suspension upgrades give an extra 115" travel.
going by the reviews ect its no slouch, but given its an off road focused car (not like the trucks like the SRT10 Ram and SVT F150 Lightning)
Then again every review i have read has been done on dirt
Edited by Whiplash
ok so i havent flooded you with Speedhunters for a while, but i had to post this
It is one of many demonstration cars that are kept at the shop and used on a daily basis by the man himself. Like most of the cars that come out of Rocky Auto this Skyline has been given a new breath of life, with a series of modifications that transform it into a very modern feeling car. Power is courtesy of an RB25DE, which is smooth and powerful, allowing the classic Skyline to retain its original straight-six feel.
The interior looks factory enough...
...until you take a closer look. That ignition looks a little too modern doesn't it? That's because it's taken from a C33 Laurel, much like all of the lower section of the dash board, the wiring loom and even the steering mounted stalks.
All four manual windows have been converted to electric-operation by using the motors and commands from a later generation 70's Skyline model.
The car may sit a little high, but it's been set up like that to allow it to clear ramps and other urban obstacles one may encounter.
Behind the Watanabe front wheels are 4-pot Nissan calipers taken from an R32 GT-S typeM. The front suspension arms and linkages have been borrowed from an S13 Silvia while the dampers are from an S14. Rocky Auto always takes great care underneath the car, trying to make the handling more akin to a modern sports car. They certainly know what they are doing!!
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
