hahahah nice
i like
Let's cut to the chase. I've never been in any car that accelerated as hard as this hairdresser's car and I've been in a lot of fast cars in my time as a speedhunter. Most of the really fast cars I've experienced were race cars of some sort. But this Mazda Roadster is born and bred to be a street car, putting down killer times at the drag strip is just a part time job for this little guy.
Glen should do this conversion
This monstrosity is what lays inside the engine bay. It's an RB25DET from a Nissan R34 NEO Skyline. Imagine 711 horsepower and 581 ft/lbs of torque, on Q16 VP race fuel, in a car that weighs in just around 2500 pounds. A Greddy plenum intake manifold sits to opposite to the custom made turbo manifold. A Greddy fuel rail with 660cc Seimen's Deka injects and Greddy intercooler was also installed.
Inside the engine is a set of 87mm Supertech 9:1 forged pistons, ARP headstuds, ARP mainstuds, ACL Calico coated race rod bearings, and a ACL Calico coated race main bearings.
this thread requires non-car related awesome
Russian Ekranoplan
1987 was the year when the first 350 tons ground effect “ship” from the series of Soviet battle missile carriers was produced. It was called Lun after the Russian name for a bird of prey – hen harrier. Another name for this vehicle was Project 903. It carried 6 Moskit cruise missiles (SS-N-22 Sunburn in NATO classification). Hitting four of them causes inevitable sinking of a vessel of any know type and size. The second Lun-class battle aircraft was supposed to be produced in several years but due to the end of cold war and partial disarmament the project was changed to a rescue aircraft and it was never finished.
This type of vehicle called in Russian ekranoplan uses so called ground effect – extra lift of large wings when in proximity to the surface. For this reason they have been designed to travel at a maximum of three meters above the sea but at the same time could provide take off, stable “flight” and safe “landing” in conditions of up to 5-meter waves. These crafts were originally developed by the Soviet Union as high-speed military transports, and were based mostly on the shores of the Caspian Sea and Black Sea. In 2005 crafts of this type have been classified by the International Marine Organization so they probably should be considered flying ships rather than swimming planes. It is also interesting to note that this aircraft is one of the largest ever built, with a length of 73,8 meters (comparing with 73 of Airbus A380).
Lun doesn‘t have a landing gear, only a huge hydroski so there’s no way for it to get on land and for this reason a special floating dry dock was designed for it.
This hybrid vehicle is driven by 8 turbojet engines.
Functionally the body of this strange ship was divided into 4 parts: fore, middle, after-part and keel together with stabilizer. Fore part possesses pilot house and a pillar holding 8 main engines, as well as a room with secondary ones. Middle and after parts were fully equipped with test facilities but still have also a caboose and a toilet. The whole keel is filled with power installation for electricity supply during mooring and a complex of radio navigation and communication equipment. A room for a gunner is placed in a cross-line of keel and stabilizer at a height of 12 meters over the waterline.
The ecranoplan’s crew consisted of 7 officers and 4 warrant officers. It could be absolutely autonomous for 5 days.
Check the link for 3 pages of photos :)
also here is the wiki :thumbsup:
You cant count on the Ruskis for much, but if you are after good vodka or a large floating piece of metal that can destroy 9 titanics and travel real fast, they are the country for the job
yeah, times have really changed.
Back in the day, power came from big cams, big carbs & blowers.........good for the drag strip, shit around town.
Now you throw on a couple of snails with a small cam (V8 OHV) or cams (OHC) and you have not only a drag car, but a grocery getter :huh:
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
