  • Replies 67
just your typical Northern suburbs shopping basket.
youre kidding right? do you see a bong and a 6 pack of coopers pale? no? then its not a northern suburbs shopping basket.
srsly damo, you call yourself a northy...
bong? seriously Dave, 600ml coke and a garden hose will suffice, cheaper too.
you ever tried smoking out of a 600ml coke bottle? shit aint fun.
what can i say, im a higher class of northy.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
