I was faced with the same problem on the R33GTST when I had the 450 bhp target on pump 98, the rediculous cost of straight swap injectors made me search for another answer. The best solutiion I could come up with was a GReddy copy inlet manifold, a set of GTR top feed injectors and a GTR fuel rail with a Nismo adjustable fuel pressure regulator to push the injectors the fraction more necessary (440 to 450 bhp). Since I already had a set of standard GTR injectors and a fuel rail, the only cost was $400 for the manifold and FPR plus making up a resistor pack was no big deal for me.
That's not actually what the car has, due to the availability of E85 I decided the GTR injectors weren't going to be big enough, so I used 550 cc injectors (13B turbo) which are high impedance so I didn't need to use the resistor pack. Waste not want not, I used the resistor pack on the R32GTST with its 1000 cc Rochester injectors as they are low impedance.
Cheers
Gary
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4646536
On the topic of Injectors
How are those 1000cc Rochester and 855 Bosch injectors you see on ebay for cheap?
my understanding is they need a 14mm fuel rail and connectors? (on GTR so same low impendance)
they seem alot cheaper then sard/greddy/hks etc
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4647325
Ye thats beccause as you said, they dont bolt in.
probably also need new injector plugs and so on, which end of the day cost vs effort vs time... the jap direct replacement stuff probably comes close, certainly wins in the speed stakes which on workshop rates can save you money :mad:
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4648236
So really you're better off changing to a GREDDY type intake mani, and GT-R rail + injectors rather than just using drop in replacements for the RB25DET pricewise? I'm finding that the stock ones seem to be hitting awfully close to full cycle sometimes (had a light come up on the display once to indicate max duty when setting up EBC with continued 18psi runs), and are now looking at replacing the injectors rather than be dodgy and use a FPR.
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4648257
Just to clarify, the RB26 and RB25 fuel rails all bolt up to the GReddy RB25 intake manifold. The difference is the injectors / FPR. I need to clarify as im doing a 25/30 using a greddy manifold and just need to open up my options for fuel rail, injectors and fpr.
Many thanks.
Edited by Stargate
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4649018
Yes the stock rb25 fuel rail will bolt onto the rb25 Greddy manifold
aftermarket rb26 fuel rails also bolt up to the greddy manifold
im sure the stock one does too, but changing from hi impendence injectors to low you need the 26 resistor pack?
aftermarket rails also come in different sizes
most common being 10.5 and 11mm
Edited by R32 Driver
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4653532
I am in the process of testing 13 different types of JECS injectors (dont ask me where i got them from) i work in the automotive industry. these are all side feed and are the right impeadence for r32 and r33 gtst ecu's
they bolt right into the rail of an rb25 and even fit the plugs. once finished I should have availability of 440, 600 and 790cc injectors based on a fuel pressure of 42psi.
the problem with this is I have had to BUILD my own flow testing bench and calibrate it against another machine. this is due to most commercial machines do not have toe ability to test 6 800cc side feed injectors. I went a bit overboard and buit a bit of a monster and in the end spent more than a commercial machine costs building it but it is one hell of a machine.
once this is all done I am hoping to have sets of injectors available for less than $400 perhaps even $300 if i can get all the parts needed for the right price. I was sick of paying stupid amounts for aftermarket products that are O.E. hopefully I will be able to recoup some of the cost by selling a few sets.
I still need to do a bit more testing before i am happy to sell them to people but so far I have a factory idle with bolt in 790cc injectors and excellent atomisation. they will flow enough for 450rwkw safely. that should be enough for almost anyone.
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4653666
any chance of something that would fit Neo rails?
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4653741
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
