I was faced with the same problem on the R33GTST when I had the 450 bhp target on pump 98, the rediculous cost of straight swap injectors made me search for another answer. The best solutiion I could come up with was a GReddy copy inlet manifold, a set of GTR top feed injectors and a GTR fuel rail with a Nismo adjustable fuel pressure regulator to push the injectors the fraction more necessary (440 to 450 bhp). Since I already had a set of standard GTR injectors and a fuel rail, the only cost was $400 for the manifold and FPR plus making up a resistor pack was no big deal for me.
That's not actually what the car has, due to the availability of E85 I decided the GTR injectors weren't going to be big enough, so I used 550 cc injectors (13B turbo) which are high impedance so I didn't need to use the resistor pack. Waste not want not, I used the resistor pack on the R32GTST with its 1000 cc Rochester injectors as they are low impedance.
Cheers
Gary
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4646536
On the topic of Injectors
How are those 1000cc Rochester and 855 Bosch injectors you see on ebay for cheap?
my understanding is they need a 14mm fuel rail and connectors? (on GTR so same low impendance)
they seem alot cheaper then sard/greddy/hks etc
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4647325
Ye thats beccause as you said, they dont bolt in.
probably also need new injector plugs and so on, which end of the day cost vs effort vs time... the jap direct replacement stuff probably comes close, certainly wins in the speed stakes which on workshop rates can save you money :mad:
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4648236
So really you're better off changing to a GREDDY type intake mani, and GT-R rail + injectors rather than just using drop in replacements for the RB25DET pricewise? I'm finding that the stock ones seem to be hitting awfully close to full cycle sometimes (had a light come up on the display once to indicate max duty when setting up EBC with continued 18psi runs), and are now looking at replacing the injectors rather than be dodgy and use a FPR.
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4648257
Just to clarify, the RB26 and RB25 fuel rails all bolt up to the GReddy RB25 intake manifold. The difference is the injectors / FPR. I need to clarify as im doing a 25/30 using a greddy manifold and just need to open up my options for fuel rail, injectors and fpr.
Many thanks.
Edited by Stargate
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4649018
Yes the stock rb25 fuel rail will bolt onto the rb25 Greddy manifold
aftermarket rb26 fuel rails also bolt up to the greddy manifold
im sure the stock one does too, but changing from hi impendence injectors to low you need the 26 resistor pack?
aftermarket rails also come in different sizes
most common being 10.5 and 11mm
Edited by R32 Driver
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4653532
I am in the process of testing 13 different types of JECS injectors (dont ask me where i got them from) i work in the automotive industry. these are all side feed and are the right impeadence for r32 and r33 gtst ecu's
they bolt right into the rail of an rb25 and even fit the plugs. once finished I should have availability of 440, 600 and 790cc injectors based on a fuel pressure of 42psi.
the problem with this is I have had to BUILD my own flow testing bench and calibrate it against another machine. this is due to most commercial machines do not have toe ability to test 6 800cc side feed injectors. I went a bit overboard and buit a bit of a monster and in the end spent more than a commercial machine costs building it but it is one hell of a machine.
once this is all done I am hoping to have sets of injectors available for less than $400 perhaps even $300 if i can get all the parts needed for the right price. I was sick of paying stupid amounts for aftermarket products that are O.E. hopefully I will be able to recoup some of the cost by selling a few sets.
I still need to do a bit more testing before i am happy to sell them to people but so far I have a factory idle with bolt in 790cc injectors and excellent atomisation. they will flow enough for 450rwkw safely. that should be enough for almost anyone.
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4653666
any chance of something that would fit Neo rails?
https://www.sau.com.au/forums/topic/272690-injectors/#findComment-4653741
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
