You obviously have never been in a properly set up Supra for circuit racing.
I was being rather sarcastic.....have seen some mad supras on tracks
Hey Krishy, I will take some shots for ya while your in action!!
Thanks for that martin.....looking forward to it woot woot
  • Replies 383
Hey George, are you taking your Supra to this? Have you finished all the mods (turbo, manifolds etc) on your car now?
Looks like my car will be stuck in RWD with no ABS so I'll be the guy facing the wrong way each corner and having everyone take evasive action around me.
The new G sensor which my car needs costs about $3000. F**ken GTRs! :thumbsup:
jeez man buy one from a wrecker... screw a new one
-D
Gtr's run as a RWD anyway unless ur under full load. The GTR behaves like a rear wheel drive car and is very tail happy as we found out with mine and a certain V8 500 driver last week at Mallala. So you have to be correcting yourself the Attessa can only do so much and we were drifting and correcting nearly every corner and you can feel the correction with the application of front wheel drive but it still has no effect when your pushing the car beyojnd its limits and you still have to rely on your own driver skill to negotiate the turns.
yeah but he's got a fwd daily :P no chance lolz
i have no abs either, shell be right steady foot works best :P
^^ and its not quite full load or 100% rwd, watch the dial when you put ur foot down, itll go to about 10% fw torque. theres usually something going to the front but in the end 32s still feel pretty much like a rwd on most bends
Edited by Inline 6
Picked up the car from Manta yesterday and despite the G sensor indicate red and failing the diagnostic test it now has 4WD & ABS :huh:
Funnily enough when we put it on the dyno today at HiTech it didn't want to come out of 4WD despite the fuse being pulled and the Field torque split controller being unplugged. The new BlitZ EBC and oil lines to the GReddy catch can will hopefully be sorted on Thursday and I think I'll fit the Recaro race seat for the day. Fingers crossed all goes well.
Now I'm just debating whether to buy a helmet before the 25th? I know it's not mandatory but with my driving history and luck...
as the course is set up as an introduction to track days, we won't be going flat out 100% to maintain safety and also to minimise the cost to the drivers (recognising that not everyone wants to invest in a helmet if they haven't decided on whether they're going to do regular trackdays yet) but it's up to you if you want to bring one along on the day.
so I'm not familiar with how much the wear and tear will be on my car so heres what ive done.
-new tread all round
-new coolant
-mobile 2000 10W-40 oil and filter change
Do i need to have new brakes? if so whats good brakes? no green or red stuff ideas tho(too expensive) just chuck me good brand an what id have to pay for 2 pairs. i got some dot4 factory line racing brake fluid for when i put new pads in.
anything else i may need?
I'd keep your tyre pressure's at at least 30 psi, if its a cold day or raining you wont get enought heat in your tyres and you'll just slide around or roll the tyres of the rims. Take a tyre pressure guage with you and when you start to push the car hard for a few laps then check the pressure, try to keep it about 30-36psi. I doubt you guys will see much of a pressure increase as this couse is only a beginer thing and you wont have helmets so i doubt you'll be able to push your cars very hard.
actually, the instructors recommend that you start with 42-45psi with street tires to stiffen the side walls for cornering - this is Item 1 of your pre-trackday checklist that is part of the course receipt that Dean from John Bowe Driving has emailed ALL of you going.
this also prevents the tire rolling on the rim with hard cornering, but i suspect that many of you have stretched profile tires anyway :)
i would start with minimum 38psi cold (17"-18" street tires) before you leave home as it will probably rise to 40+ by the time you reach Mallala. it is better to have over inflated tires rather than under inflated as you can always let excess pressure out there (unless you have a portable compressor or pump with you). and dstroy is right - your tire temps won't increase a lot if it is a cold/wet day.
for semi slicks, you would start with 28-30psi cold as these can increase to 34-36psi when hot (after hard cornering, acceleration and braking). you would adjust the pressure for these tires in between laps based on the tire wear across the tread face (need edge to edge wear).
Edited by V35-2005
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
