  • Replies 182
Sorry Andrew -1 on this....will be able to lend you my current standard in a couple of weeks though if you still need it.
Hey mate,
Not a problem, would we be able to make up something similar to the image above off the standard shape/size?? otherwise i'll probably just use my car to make it up.
Hey mate,
I just purchased the one as per your image.
I'll get some photos of current work, he does lots of high end fabrication tho, you look in just about every high performance mag and you will find their work :D
i was thinkin of getting something done similar to the dolphin job? but i'm open to the best suggestion!! is the stock dump the same size as the dolphin job??
Flange looks tricky to source but i will pop into a shop tomorrow to see if they can get it. otherwise i will get a gasket and we will lazer cut a flange from it.
any coatings can be done also. prob best to get em ceramic coated or the like.
Dolphin dump is a different design again (much straighter)
If you are designing one, try to get it is straight as possible.
Yes the OE dump as a small cat on it. Are you able to get a cat to fit on a 3 or 2.75" dump and fit it in that space?
If so, I would be very interested as I need a cat-fitted dump pipe on mine.
Ok i have the flange, will have to get some more made this isnt the neatest.
i'll be needing a stock dump, or something soon so if anyone has that would be great. otherwise my cars off the road and dump will get pulled out..
we're open to designs on which would be best option for all. i'd rather have it like the first design, and a cat under the car in between dump and front pipe.
3inch i guess everyone is after?
If anyone is interested in a split dump pipe.
liverpool exhaust have a mild steel ceramic coated one made up.. soon to be on the market.
i'm not going to make up a split dump tho since the exhaust housing isnt split too well and i simply dont like the idea anymore. would rather have a complete 3inch all the way.
Cat after dump is not good for me personally.
I have the de-cat Kakimoto 80mm front pipe that bolts straight up to the OE dump (and to my Legalis exhaust) so I guess I will be sticking with the OE dump.
Ok, will see what the majority wants really. but it may not be a problem to modify what you want done. will obviously cost more since there is a Pussy involved..
Understandable.
Let me know if there are any options for a cat to be added to the dump. If not, no stress.
Gotta have at least one cat as I don't want all that carbon sh!t on my rear bumper.
Edited by iamhe77
Understandable.
Pussy and cars dont mix :D
if the dump we make is long enough to house a cat i dont see a problem.. just clearance may be an issue, and it will be welded on permanent i'd say/
will try get stuck into this this arvo when i finish work
What do you want a cat for anyway? :) Will talk to you on Sunday about the possibility about lending it....will be about two weeks till I get it though.
cheers
Craig
cheers
Craig
Hey mate, sounds good.
yeah i dont like cats at all, like trying to breathe thru a pillow :D
i'll either be pulling mine apart tonite to get the standard dump off to make a jig out of or borrowing one. the standard dump will be fine..
so chances i may not even need to borrow it..
thanks anyhoo :)
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
