nitrous or head work
73 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 48
Posted Images
yep o/s s/s valves port job from one of the best pro head porters (the phantom) matching manifold. cam gears, valve springs i have cams i have 256/264
it will be for drag and every day with water meth
and
75 hot nos for the same reason but not on the street.........maybe
headjob for the win
id be looking at what i want the power for
do you want that extra burst of power to try and break into the 10s at the track---nawz
or do you want less power but have it all day every day---head work
yer i was hoping for more than 20 votes
heads good but 6 week wait nos 1 day
Go the nitrous or do both. I still want to do the nitrous but im worried the motor won't last long and i can't afford a rebuild until i finish uni. I have the nitrous bottle in my garage lol.
You said the price is only $200 difference, how so? The NOS wet kit i want is only $700-$900 for the kit depending where you buy from. What kit you looking at?
nos kit installed and dyno tuned so i get the best out of it ill pm you the price
Hmmm the kit i was looking was the NOS05130 kit, you can see it on this site http://www.bottleorboost.com.au/FORMgallery.htm
Then a purge system, bottle warmer and a electronic bottle opener if you wanted aswell.
I suppose with installation (I was going to do it myself) and dyno tuning it would come to the price you said.
Edited by PM-R33
what to do this is the thing
see i know ill use it on the street and the water meth came to day as well from the states with progressive spray.
If i was in your position and had a built engine, i wouldn't think twice and just go the nitrous.
Which water-meth kit did you go? I'm still looking into it myself. Trying to make the kit look nice and neet under the bonnet is the hardest thing, the pumps are so huge! My mate wants to put one on his 30/25 once it's on the road, so i'll see how that goes.
Those nitrous kits can be hidden very well with a couple of tricks and a cop wouldn't look twice if you hide it right.
Edited by PM-R33
very true
i like this one
ZEX SINGLE FOGGER EFI WET KIT
100hp shot of gas. Lenghten the lines between the solinoids to the fogger for a "softer" hit. Make shure your fuel pump can flow enough fuel for the extra 100hp.
More power
Cooler intake charges
No waiting to get your head back and get the car on the road
Faster spool up
Upgradable system, for future power gains/reliability
Paint the bottle yellow and tell the cops it's a fire suppression system??? ha ha ha
Like any power adder, as long as you tune it right your motor should live a long happy N20 life. I raced for two seasons with N20 on a 400rwkw 15yo 26 without a hiccup.
I love gas!
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
