well im guessing alot of people have coilover suspension setups out there, but who knows where what can be rebuilt/repaired by who when something needs fixing. as far as i know, Fulcrum do work on Tien suspension, but currently im in a pretty sticky position. i have Top Secret coilovers, and need my rear pair rebuilt. i have no idea anyone who can work on them other than Top Secret japan. i havnt even heard of anyone else in Australia running this coilover setup before!
so how bout we make this a guide for others out there in need of a hand :down:
https://www.sau.com.au/forums/topic/272951-rebuilding-coilovers/
i bought some second hand coilovers a while back i fitted them and took the car for a drive only to find out the rear pair was knocking, i got a quote to rebuild them :down: and for a little extra money i could buy new ones. in the end i sold the coilovers and fitted some the stock ones back. with rebuilding coilovers you have to remove the strut top and spring so your only left with the dampener then you have to send it to a workshop which could take 2 or more weeks to do in the end some shops will charge u around 300 per shock. If i was you save your money and buy a full set of new coilovers because in the end once you fix the rears one day your going to have to fix the front set as well. don't quote me on costs and my sentence structure sucks as i just finished work.
Edited by Greekos
  • Like 1
Firstly the bad news, Top Secret don't make shock absorbers, they buy them from a shock absorber manufacturer and put their stickers on them, whack them in a Top Secret box and double the price, actually triple is closer to it. Really, that's good news, because Bilstein is one of the manufacturers they use. My best suggestion would be to take them to Sydney Shocks and get Paul to have a look at them. He will then be able to tell you what they are, if they can service them and approximately how much it would cost.
Cheers
Gary
  • 2 months later...
  • 1 month later...
Im looking for someone to do HKS shocks also. Mine are stuffed. Im actually thinking of buying a new set of bilsteins instead. there is a place in QLD who may be able to do it
http://www.shockreco.com.au/reco.htm
shockreco are good only downside is they are in qld , they do heaps of cars and various suspension setups
they did my old integra setup :)
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
