  • Replies 88
A man walked into the produce section of his local supermarket and asked to buy "half" a head of lettuce.
The boy working in that department told him that they only sold whole heads of lettuce. The man was insistent that the boy ask his manager about the matter.
Walking into the back room, the boy said to his manager, 'Some a***hole wants to buy a half a head of lettuce.'
As he finished his sentence, he turned to find the man standing right behind him, so he added, 'and this gentleman kindly offered to buy the other half'.
The manager approved the deal and the man went on his way. Later the manager found the boy and said 'I was impressed with the way you got yourself out of that situation earlier. We like people who think on their feet here. Where are you from, son?'
'Queensland, sir,' the boy replied.
'Well, why did you leave Queensland,' the manager asked.
The boy said, 'Sir, there's nothing but whores and rugby league players up there.'
'Really!' said the manager. 'My wife is from Queensland!'
The boy replied, "No shit??? Who did she play for?'"
i lol'ed
ps. QLD > NSW :)
https://www.sau.com.au/forums/topic/272975-qld-suck/page/3/#findComment-4635459
Four surgeons are taking a coffee break.
The first one says, "Accountants are the best to operate on because when
you open them up everything inside them is numbered."
The second surgeon says, "Nah, librarians are the best; everything
inside them is in alphabetical order."
Third surgeon says, "Try electricians. Everything inside them is
colour-coded."
The fourth one says, "I prefer NSW fans. They're heartless, spineless,
gutless and their heads and arses are interchangeable."
my god kudos to that hahaha Im a bit late but GO QUEENSLAND glad they one... by the by jarrod (Knob) haynes foot was on the line by a flying f*cking mile... Victory Dance :bunny:
https://www.sau.com.au/forums/topic/272975-qld-suck/page/3/#findComment-4637216
those joke fail fairly badly
so in summary NSW sucks a humour and league
P.s. if the cockroach in the first joke was so smart he would have realised the the Murray-Darling starts in QLD and would fill the state pretty quickly with our new impervious wall and he could have saved his wish and maybe used it to get a team capable of say....winning origin?
wouldn't need to if the was no one to play for qld now would we
https://www.sau.com.au/forums/topic/272975-qld-suck/page/3/#findComment-4646629
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
