I was at chasers the other day getting my brakes done and quized there tuner Paul about Nistune and if they were going to do them he informed me they had started to do them. Quote for a S2 stagea auto drive in/out including supply,install and tune will be around $750 mine will be booked in very shortly and i will supply b4 and afters to let you know how it goes. Contact glenn at chasers for all enquiries (03) 9687 7118
https://www.sau.com.au/forums/topic/273091-s2-stagea-nistune/
what does the the nistune chip do ?
like a piggy back comp ?
the nistune chip sits in the stock ecu (so totally invisible) and can control afrs, timing, change rev limit and more importantly remove 180km speed limit. Sadly they are not available for S1 Stageas.
Awesome! I'm really keen to see some before and after figures on the NIStune. I wouldn't mind getting this installed as soon as i can. Also be interesting for traveling sakes how much different the car will be on fuel before and after. Do you have any other mods on the Stagea to go with this?? :P
Just got my nistune on my s2 rs auto stagea redone yesterday. Had some misfiring issues due to plugs but now its bloody amazing!!!!!!!!!
Before my tune with stock turbo and safc neo( which is now for sale :P )i managed 185rwkw at 12psi with all usual mods and stock afm, injectors. Now with hypergear turbo and nistune i'm pushing 230 rwkw at 16 psi!!!
The nistune transformed the engine completely. No where near as laggy, cold starts are perfect and changes on the stock auto are really snappy at the top end with no flaring. Funny thing is before the nistune my auto would flare for a second before changing to second, now it just clicks in really quick!! Hope that lasts!
On an rs rwd stagea this setup is so much fun! I'm getting to the limit of my rear tyre traction, and best of all i'm managing 450km + to a tank enen with a heavy foot and city driving!
Go the nistune definately, had mine done at status tuning by trent and he is fantastic!!
Before my tune with stock turbo and safc neo( which is now for sale :D )i managed 185rwkw at 12psi with all usual mods and stock afm, injectors. Now with hypergear turbo and nistune i'm pushing 230 rwkw at 16 psi!!!
Nice! i get more pumped to get one installed every time someone talks about them!! :P
Awesome! I'm really keen to see some before and after figures on the NIStune. I wouldn't mind getting this installed as soon as i can. Also be interesting for traveling sakes how much different the car will be on fuel before and after. Do you have any other mods on the Stagea to go with this?? :banana:
I had my car dyno'd when i put a boost controller in pulled 178 rwkw on 12psi dropped to 8 psi @6000rpm, since then i have installed full 3" turbo back exhaust and an adjustable cam gear, car came with hks intercooler and pod. All my driving is on highway get about 520 kms per tank but never run it empty so maybe 550-600 out of a tank. will post up results of new tune as soon i have it installed prob july/august
WOW - didn't know Chaser's do Nistune...another option for me, Although Trent at Status Tuning is the highly recommended, it's simply too difficult to get over the other side of the city to get it done (at my work, I can't take time off because we're short staffed).
2 of my friends got their cars tuned up at Chaser's and spoke very highly of them
sorry guys slightly off topic, but a bit interested if you have got a std turbo andy(i guess it is at 178rwkw on 12), have you any other mods eg safc etc to improve fuel use or a block behind the fun pedal because all stagea owners would cut off a nut for those figures :banana:
That figure was on the Chasers dyno in rear drive only (fronts pulled out) and as the car came from japan. Stock turbo (as far as i know) stock dump pipe and hks silent power cat back,hks intercooler and hard pipes and hks pod and turbotech bleed valve set to 12psi as stated. As for ecu i have always assumed it was standard it however may not be but never looked to see i guess i'll find out when the nistune goes in. There was nothing on the auction sheet to indicate modified or changed ECU or turbo and no sign of any aftermarket electronics (safc/sitc). I found the dyno sheet i over quoted a bit real figure is 175.6 RWKW unfortunately i could not get a print out of AFR's
Edited by AndyD
Would this be a better option than jaycar AFR & boost controller with hand controller, which I was thinkin of doing. It's a bit more expensive but if the outcome if much better.......?
Any ideas on who I can talk to about getting this done in Brizzy?
Cheers-
Cheers-
EFI Performance. They are at Yatala or Nerang
I might be going down this track. Approx $300 plus tune $500.
Opposed to the Vipec for $2600 installed and tuned
Cheers-
Nistune will be better than just getting the Jaycar DFA but you will still need a boost controller and the Jaycar is great value if you can build it or find one already built).
Lose the stock dump for something (anything?) else, and fit a decent cat. turbine noise is a bit louder, but best estimates put those 2 parts fitted to my car alone at being worth ~5awkW (with a stock cat-back).
Otherwise, stop talking about how good the Nistune is - us S1 owners get all upset about it...
:P
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
