Hi! I know that the carbon fibre and fibreglass of the Z Tune bonnet is illegal to have in Vic. ( as long you don't get busted :bunny: )
But if i get a bonnet scoop like this one:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...mMakeTrack=true
And get it moulded to my original bonnet. Is that legal?
I know that some of you will ask or even bag me about having the z tune bonnet when i worried about it being legal or illegal.
Well if i do get defected, i wouldnt know how the hell i would get time to get it fixed and also the money involved to get it fixed.
Therefore looking for a alternative to get the Z Tune Look.
https://www.sau.com.au/forums/topic/273252-r34-z-tune-bonnet-scoop/
general rule is any non-standard or rather non-factory part without ADR approval is illegal. I think if you get a V-spec II CF bonnet or Z tune GENUINE bonnets then they will be legal as they are factory standard.
Look-a-like bonnets without ADR approval are illegal. Maybe it differs between states...
I have a mock up z tune bonnet on mine, rarely get hassled about it then again my car is all black so it doesnt stand out as much. pretty much another carbon fibre or fibre glass is illegal to have unless it is ADR approved mentioned above. i'm unsure of the genuine factor of a v spec / z tune bonnet but i can imagine getting your hands on a geniune one will cost you an arm and a leg!
oh and if you were to get defected for it, the only way to clear it would to put on your stock bonnet and clear it with it on, bonnets are very easy to take on and off and swap, only 4 bolts. just need the extra hands there to help put it on.
Like everyone above said...if it's not from the factory then it's illegal. Moreover, you're going to cut through the bonnet and mount the vent yourself - so this means you're tempering with the stock bonnet, I would say it will definitely be illegal. However, having said that - most Skylines on the road aren't stock - far from it, so like, who cares...you'll be done anyway...if you're car is stock, then that's a different story...you get my drift, right?
stock bonnets aren't expensive ..I've seen quite a few range from $100-300 both here on SAU and various skyline shops (as a lot of people trade theirs in when getting an aftermarket one) so if you eve get defected ... but having said that, why not just keep your stock bonnet just in case? Whatever you do please don't get one of these stick-on fake ztune vents ..it just looks tacky and ghey and brings shame to your village..
Fair Enough, but if i get defected, doesnt that mean that i have to change bonnet, spend money to get RWC and then show the cops the RWC agian?
Plus i just got a quote, $250 to mould and $250 to Paint my bonnet = $500, might as well just get a Fibreglass version LOL
Why don't you just get a R34 GTR V-Spec II bonnet?
Comes from factory Carbon Fibre and has a NACA Duct for cooling on the turbo side.
Or even buy the 3" NACA Duct from www.kenlowe.com.au (based in Qld) and buy a little bit of SAAS black mesh.
On his website, just scroll down to 'Raceglass Composites - bodies,scoops' and scroll again till you see 4" & 3" NACA Ducts
The Duct costs $49 + GST + Post. It's an exact copy of the VS II
Placed in the correct spot, the Duct does not interfere with the reinforcement underneath.
  • 2 months later...
Where is the cheapest place to get a genuine vspec II bonnet?
Im presuming they will be 1-2k?
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
