hey guys just putting my input. I have bought the kit from sxexcx's and put it onto my V35. Everything fit 100% and the only problem is the battery was on the other side. Therefore putting my idea i basically swap the connection the other way around.
sxexcx's instruction:
Wire #2 suppose to connect to the battery
Wire #8 suppose to connect to the Grounding point on the Brakes compartment.
My install:
Wire #2 connect to the grounding point on the brakes compartment
Wire #8 connect to the battery
The improvement i have is the Car definitely running much smoother and more responsive. The Auto Gear shift also crispier and noticeably quicker.
The DIY term is pretty easy install for the engine bay, except the Auto transmission point. You have to go underneath the car to install it.
I cannot provide the Dyno results as this mod is not to increase Horsepower/KW, but to improve the responsiveness and smoothness of the VQ35 and shifting time on the CVT Auto Transmission.
Also the kit should fit on the Sedan with VQ35 as well.
hope my review helps
Thanks so much!
  • Replies 212
Hey pw350GT,
Thanks for sharing that information man, really handy to know. You're in VIC right? We've gotta catch up with a couple of others sometime on a weekend for a meet and greet soon!!!
Well if you want colour choice AND more than just the basic grounding kit of 2 cables, then as I suggested before, contact Marty at FHRX. He's been making grounding kits for years and they usually come with a minimum of 6 cables. He also uses Stinger which is some of the best automotive cable available.
This is the kit I purchased for my Calais some moons ago, here is his correspondance when purchased this kit for $215AUD delivered.
I make them up here from scratch for each and every car. They include the
five lots of 4AWG runs that go from the rail to the different parts
of the car. The kit also includes the 0AWG that goes from the earth rail to
the negative terminal.
The cables usually go:
1. starter motor
2. shock tower
3. shock tower
4. head
5. plenum
They are all terminated with ring terminals except the starter motor wire,
which has a coupler on the end.
Regards
Marty
examples below, scroll down to next group of images and click on image for larger view.
http://www.fastfoursforumscarclub.com/temp...t.asp#interest8
Edited by mosoto
Hey pw350GT,
yeh shall do.
:D
hey mate,
how much do you think he would charge to install?
I'm not sure but keep in mind
1) it would be cheaper than what I quoted above IF you decide to have only 2-3 cable grounds as per the US kit.
2) It would be cheaper again if you do the GB thru' Marty (well you'd think so)
2) If Someone living in Sydney can have it installed by Marty they can take pix of the installation and post em up for all.
Thanks for the suggestion, but i think i will stay wif this kit, id get something made for OUR car rather then something custom, and the good thing about this kit is all the grounding points are all clear and the length of the kit is perfect for ours. and also the price, around $140-150AUD i don't think u can get any better ones in for that price. thanks
I think im gonna get someone to install the GB kit for me....I dont have the tools to start going under the car to install things.
just wondering how much it will cost, I'll call on Tuesday.
Cant wait for this kit to improve my AT gear changes!
how to fix the RHD and LHD issue? the battery will b in different side
Each to their own I guess, but let me take a minute to digest your logic.
1) You want a kit made O/S by a forum member which in essence is a custom non-proprietry kit as it's not made by Stillen, HKS or Greddy!!!!!!!
2) The kit from the US is 8awg not 4awg as offered by the local "pro". ( btw 4awg is bigger than 8awg if you were wondering ).
3) The US kit has primarily 2 grounds but lots of runs of cable grounding "nothing", just piggybacking around the block. Look carefully at the pics of the US kit and compare to those on the FHRX site. To successfully ground the Alt/Batt/Starter etc they need to run directly to a grounding point on the chassis to be completely effective. With the FHRX kit each run is connected directly to ground.
I just can't visualise the US kit being as good or better than what Marty or any other proffesional Car Audio installer could do for you at the same price point.
just my 2c !!!!
Edited by mosoto
just my 2c !!!!
I know this kit is 8awg and not 4awg, but anything more then 8awg is really a waste, im not using the wires to run ur hifi wif 1200w, and im also not as "pro" as u can tell by the pictures that "the cable grounding "nothing", and just "piggybacking" around"! im sure he made this 9 wires has to hav his reason.
and 4 the reason why im getting this kit, bcoz it is made for our car, and someone has gotten them here and having good reviews, so i don't get the point why not? even it's a custom kit, but he has been "custom"ed to many of our cars out there already, those FHRX, mayb they're very pro and knowing where to ground and grounding "something", but do they know our car more then the guy in US has done alot of them?!
thanks for ur 2c~ lol
danny if you want i can help you install it if your in sydney and have a free weekend
i cant imagine it being too hard
i installed the Z tube myself, and i will be doing the plenum spacer too. might as well do this one also.
-mark
-mark
hey mate that sounds good, very kind of you.
too bad I don't have my plenum yet, since I missed out on the GB!
btw, was your car parked on Castlereigh Street in Sydney on Friday night?
the sydney people could have a Mini meet for the Install lol. It's seriously not hard to install. All you need is the size 10 spanner or Ratchet and some sharp knifes :thumbsup:
It is easier for the people that have the Manual as you don't need to get underneath the car to install the last point for the Auto Transmission.
Well said!
Just a couple more guys~````
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
