  • Replies 212
guys how much is it all up? my page viewing is wierd i have to click on everyones post to see what they wrote lol.
im in wa and if its ok for me to be in for gb ill like blue and willl pay for postage once it arrives in aus to be sent to wa?
it cost $115 USD if we can get more then 10 ppls, so will be around AUD$150, and ill send it to wa for ya once it arrives syd. but not sure how much~ should b around $15?
thanks
Hey Fox, can you please count in for a set of Blue.
Thanks.
1. FoxV35 (BLUE)
2. moomoolulu (BLUE)
3. danny_tg (BLUE)
4. BLISTC (RED)
5. Siglapian (MATTE GREY)
6. MILLOS (BLUE)
7. V35 Matt (RED)
8. Popeye (Blue)
I thought I'd better come over from the 350z-tech forum and join in from here.
1. FoxV35 (BLUE)
3. danny_tg (BLUE)
4. BLISTC (RED)
6. MILLOS (BLUE)
7. V35 Matt (RED)
8. Popeye (Blue)
9. Vai350z (Blue)
Just got a pm from FoxV35 saying that my last minute decision was accepted =D so with that i'll update the GB while im at it:
1. FoxV35 (BLUE)
3. danny_tg (BLUE)
4. BLISTC (RED)
6. MILLOS (BLUE)
7. V35 Matt (RED)
8. Popeye (Blue)
9. Vai350z (Blue)
10. xtc (Blue)
11. Will Power (Blue)
Edited by Will Power
Is it too late? I'm still a bit worried about not being able to get underneath the car to get to the transmission
1. FoxV35 (BLUE)
3. danny_tg (BLUE)
4. BLISTC (RED)
6. MILLOS (BLUE)
7. V35 Matt (RED)
8. Popeye (Blue)
9. Vai350z (Blue)
10. xtc (Blue)
12. rs73 (MATTE GREY)
