hey guys, I need some help, with obtaining measurements of an rb26 N1 block.
any help will be very appreciated, please specify what points you are measuring from, and if possible please include pictures of every possible angle of the block (front, back, top, bottom.etc).
thanks guys
https://www.sau.com.au/forums/topic/273293-rb26-n1-block-measurements-and-pics/
common guys, we need measurements from the following points:
center of crankshaft to top of block
top to bottom of block (front), back to front (top and side) longest points
need lengths of spacing in the cradle (edge to edge-please specify where you measured) need width of cradle journals.
please, any help will be appreciated
I think its a case of no one just having N1 blocks sitting around. :)
Best bet is to just buy one if you need to do anything specific with one
just a bit to expensive for us at the moment mate, could someone just measure up a standard one from the specified points please?
I also would...but I only have the RB26DETT...not N1.
sorry.
would you be able to grab some of the standard block please mate? It seems no one has an N1 block at the moment.
If anyone has an rb26 block for sale near brisbane we will buy one to get measurements.
thanks for the reply's guys.
cheers
sorry.
cheers
On that note, I am guessing a RB26 N1 Block is the size as the Normal RB16 block as it is the same engine, just made from stronger material.
N1 blocks are cast from the same parent material as 05U blocks. The difference is thicker cylinder walls and deck thickness to prevent bores splitting and cracking around the head studs which 05U blocks are prone to.
Thanks for clearing that up! :down:
But size wise it is still the same..?
cheers
Sure, can measure it tomorrow if you want. from which points? just length and width of the block itself?
I have a RRR block sitting on my stand waiting for my car to arrive. I can measure that on the weekend if you like.
Let me know ...
yeah thanks mate, that would be well appreciated,
hey mate, yeah from the above points, and any diagonals. that would be great
cheers guys, thanks for the intrest
Let me know ...
want to sell that block? or swap + cash your way for a brand new N1 block.... :P ?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
