Hi everyone,
I'm in Adelaide and now going to buy a Skyline R34 in Mel next month, right now the problem is that the seller dont have time to do the RWC. So is it possible to do it in SA? I also heard that the paper work in Mel is different to SA, they must do RWC and sign agreement before they can sell the car, is that true? So if its possible, can u guys explain to me how to buy a car from Mel and transfer it in to SA plate STEP BY STEP? English is not my first language so I need ur guys' help!!! Plz!!!!!
Thanks
Andy
https://www.sau.com.au/forums/topic/273520-buying-cars-from-vic/
Pretty sure they do need a RWC to sell, best ring Regency park on tuesday and see what light they can shed on it for you. Their number is 13 10 84, maybe some of the other guys on here might be able to give you a few more pointers aswell.
Edited by Jamesrb25
Thanks for your help mate, I'll try my luck there on tuesday!
You dont need a RWC to register it in SA, and he can sell you the car without the RWC done. You just need to sign a form saying that you knew about it and that it is your responsibility to do it before ownership transfer, which wont matter as you're registering it in SA.
hey mate.
my 260, i flew over, braught it, chucked it on a truck... when it got here i drove it for a few days then went for my identiy inspection...
they match the chassie number to the engin vin n all that jazz... and just look to make sure u have good tyers, dont have black windows n 3 1/2 strait thew exhaust :D... basicly... i gave the dude the import papers, qld rego n all that but i dont think it matters. just aslong as u prove its urs with that slip, the numbers match its easy.
Hi everyone,
Thanks
Andy
I did exactly that with a R33 GTR a couple of months ago, see my post.
http://www.skylinesaustralia.com/forums/In...-T-t267077.html
There is much information on the topic on this forum but much of it is contradictory.
How to buy car from Vic:
1. Check the car isn't stolen, damaged, or under finance by running a vehicle check on vicroads.
http://www.vicroads.vic.gov.au/Home/Regist...orePurchase.htm
2. Goto vic, check whatever you want to check on the vehicle.
3. Sign a contract, something obvious "I seller have sold my car to buyer on date. sign date lots, witness" and both take a copy.
4. Hand over your cash and take the keys - I used a bank cheque. Get a receipt if possible.
5. Rego cant be transferred so you have 2 options here - Drive the car back with the current rego or get a 1 day temp rego from Vicroads. Option 1 is best as you now have a registered car that can be driven for up to a month in SA as is, but the seller must understand that he will get the speeding fines etc so dont do anything stupid. Option 2, you need a temporary rego from vicroads that says exactly where you will be going, you will need a temp rego when you get to SA too and then you cant drive your car after you get it home until you go through regency. Take option 1 if possible.
6. Goto regency, fill out paperwork, go through an Identity Inspection. Its not a roadworthy as chef_stagea said, so don't have anything obviously illegal and you'll be fine. Get new plates for your awesome SA registered beast.
7. Post back the vic plates (especially if they are custom as they are state specific and are useless to you).
8. claim a refund on the vic registration, they sent me a cheque for $300 :)
I have in-dish rims and an aftermarket front but wasn't a problem.
Hope that helps.
i would be hesitant to buy without a roadworthy...
i looked at car from melb "didn't have time to get a roadworthy" when i got the vehicle inspected it had a stack of problems.
the second car which i actually bought was modified more than the first but the owner was still willing to put it back to standard and get a road worthy. they aren't as strict over there so it didn't take too much.
id be carefull and before you go thru for an id check put it back to stock, cos if you get a grumpy bloke check your car your in for a defect. and its over the pits b4 you know it lol, trust me ive been through it a few times.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
