Hey all
freaky, but I bidded on, and promptly forgot about, a S2 steering wheel and automatic shifter unit.
won for $40 total.
Quick question - how "possible" would it be to setup the auto shifter to work with the series-1 auto?
Ive got access to Mike from MV Automatics at blackwood, just up the road for me; with him being the auto wizard Id think it could be possible
your thoughts?
anything special to it? or simply plug and play - ie install and use
Id think Mike @ MV Auto should be able to set it up if I cant...................
when I 1st bought my stagea I really wanted the S2 for the larger turbo and triptronic auto shifts, but 18k compared to 26k just wasnt in my budget.
now, for $40, auto service and some fiddling around to install, say $450 max(?), its affordable to do, and it'd make my powerful Rb25 that much more fun to drive.
peace :D
https://www.sau.com.au/forums/topic/273577-tiptronic-shift-into-s1-stagea/
bitch you outbid me.wunder if it was darrins
bwahaahhaha Mike
welll... i don't know how soon you want to go about it but i'll soon be replacing my s2 tiptronic setup with a manual box so if you want to work something out pm me - i'm in adelaide too :D
cheers Mike, I'll go see Mike at MV's and see whats possible with my current setup 1st.
Reminds me of lyrics from a Beastie Boys classic song:
"Here's another one for y'all to peep,
It's called M-I-K-E on the M-I-C..."
Right around 3.30 in this clip, but it appears in another song too, just can't remember which one.
By all means see the specialist but I fear it may not be that easy. The gearbox is the same but the auto ecu may be different. With the S1 the auto ecu is inside the main ecu which is why I am having trouble getting a chipped ecu. Since the S1 ecu can't (easily) be chipped X-tune has chipped an R32 ecu but that doesn't run the auto. So he is basically piggy backing both ecus together. With the S2 this is not necessary which makes me think that the S2 auto ecu may be elsewhere. In that case you may need an S2 loom, ecu, and auto ecu but the neo injectors and cam control are different. Nothing that can't be overcome! On the bright side if you do all that you should be able to run a Vipec or Nistune!
Hopefully I am wrong and it will be very simple.
i thought the trans had slight differences, as i know the service kits and valve bodies are different
nope, S2 auto ecu is apart of the engine ecu aswell. its just easier to chip because it has a different chip type than the R33/S1 Stagea.
Please correct me if I am wrong, I was of the impression the S1 Stagea had an R33 Series 2 motor and ecu with an R34 pin pattern.
Yes you are right but although the plug is the same as the R34 the pinouts vary in a few cases and the ecu internally is not exactly the same as either the R33 or R34 Skyline.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
