hey guys have a r33 gtr with stock afms on it just had the car back from the mechanic wat we thought was the coilpacks or spark plugs were f**ked ended up being 1 of the afms one is doing wat it is ment 2 do while the other is doing its on little thing there for once on boost it goes into limp mod.
Now wat i heard is there is a possible tune u can do 2 them make them run right again just woundering if any1 has heard of this all has done this an if so how.
cheers in advance 4 ur help
Neil
https://www.sau.com.au/forums/topic/273733-r33-gtr-air-flow-meters/
yeah not sure what you mean, you could try contact cleaner to clean the sensor if its covered with gunk
but if the actual sensor is shagged, then its dead, no point try to fix it
2nd hand GTR afm's shouldnt be that much, new ones on the other hand...
access autoworks list Z32's for 295 then 30each for tomei plugs... that with a power FC would cost the same as an autronic SMC, autronic might be cheaper!
and then you gotta make the piping fit
hence just buy Nismo's @ ~$900 delivered and be done with it.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
