The brakes sticky is getting a bit long and posts lost.
I've found these Brembo brakes and am fairly sure I've worked it out right and they will go on my M35 (i believe they've come off an ARX) but any help appreciated.
Details:
bremboF50 & Lotus caliper? 370×30mm&340×27mm (F12mmR10mm残) × 1 cars caliper Stagea M35 KIT (Status mount) × 1 370 × 30mm & 340 × 27mm 2 piece rotors
cheers
https://www.sau.com.au/forums/topic/273773-will-these-brembos-fit-on-the-m35/
Is this a yahoo item?
i guess your going to be perfect you will need wheels 17 and upwards, but the stagea has them right? (i've not even looked at sizes)
The f50 kit on the gtr uses new caliper mounts, the things on the left in the photo which i am guessing will be included..
Details:
cheers
Yes.
But you will need to have 18's (minimum) to clear the calipers.
RS 17's won't clear.
depending on how the 17's offset you will be able to fit 17's for sure..
i only have 17x9.5 on the gtr and there is plenty of space
and this is with a new rotor/hat setup i had to get made up here as sourcing new rotors from anywhere was difficult
there is no chance fitting 370mm rotors and F50s under 17inch wheels. yours look like 355mm max or even 343mm maybe?
Ahh shit i just noticed he said 370mm that is alot larger than what i have!
i did however fit some pretty flat design wheels to the gtr also, volk gtu and also the r34 gtr wheels and also some old styled advans the volks however were a close fit.
should just buy these, have to run 19" wheels minimum by the looks but :(
http://page4.auctions.yahoo.co.jp/jp/auction/d94092768
I'm guessing thats the calipers hes found.
not a bad price so far, good luck with them if you get!
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
