  • Replies 64
Hey guys, i've got an R33 thats had a hit on the passenger side door, so it's being parted out. Its a '96 S2 R33 Gts-t with approx 82,000 ks, in silver (KR4). Located in sydney
Engine and Gearbox are sold
Front end (headlights, bonnet etc) sold
Apexi Catback exhaust, pickup only! - $300
Batmbl stainless split dump/front pipe, pickup only! - $200
Catco 3" hi-flow cat. To suit r32/r33, maybe 34? - $100
post-35556-1244447526_thumb.jpg post-35556-1244447504_thumb.jpg post-35556-1244447939_thumb.jpg
Engine parts:
Standard turbo, good condition. Minimal/no shaft play - $250
S2 Rb25det manual ECU - $100
S2 Rb25det engine loom - $200
S2 Rb25det coilpacks - $100
S2 AFM, has one cracked mount - $50 ono
Aircon compressor pump - $100
Power steering pump - $100
Alternator - $80
Stock exhaust manifold - $50
Turbo oil/water lines + banjos - $50
Rb25det injectors + rail + FPR - $120
Rb25 Engine Mounts - $80 pair
S2 throttle body & TPS - $50
AAC valve & gasket - $50
coilpack cover - $50
CAS - $50
o2 sensor - $40
A/c condenser - $150
Aircon thermo fan - $60
Rubber intake pipe - $25
BOV recirc piping - $25
Crossover pipe + Stock BOV - $50
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel + filter - $100
Stock SMIC piping - $50
Stock sidemount intercooler - $40
Bm-44 non-ABS brake master cylinder - $80
Also have a spare S2 ABS pump - $100
post-35556-1244447957_thumb.jpg post-35556-1244447980_thumb.jpg post-35556-1244448093_thumb.jpg post-35556-1244447851_thumb.jpg post-35556-1244447992_thumb.jpg post-35556-1244449685_thumb.jpg post-35556-1244449909_thumb.jpg
Suspension & brakes etc:
Apexi WS Damper coilovers front & rear - $800
(only fronts pictured but its a full set)
Front calipers - $280
Front rotors - $50
Rear calipers - $160
Rear rotors - $50
Front lower control arms - $70 each
Front upper control arms - $40 each
Front 5 stud hubs - $80 ea
Rear 5 stud hubs - $150/pair
Rear strut brace - $100
Rear GTR swaybar, 27mm - $100 pickup only!
Rear lower control arms - $50 each
Handbrake assembly & cables - $150 pair
Manaual (4.11) diff - $200
Driveshafts - $50 pair
Interior:
GTR Instrument cluster (vspec) ~82,000ks, great condition - $250 ono
Floormats - full set, drivers side front mat has slight damage - $80
S2 Steering wheel with airbag - $250
S2 Gear stick surround - $50
S2 Ashtray - $20
S2 dash pad (with passenger airbag) - $300 pickup only!
Drivers side window switch - $80
Boot interior + carpet - $80 pickup only!
Climate control - $50
post-35556-1244449145_thumb.jpg post-35556-1244448540_thumb.jpg post-35556-1244448608_thumb.jpg post-35556-1244449113_thumb.jpg post-35556-1244449129_thumb.jpg post-35556-1244449162_thumb.jpg
Glovebox - $40
Passenger door motor - $50
Centre console - $50
Drivers seat, has some wear on the side where you get in - $50 pickup only!
Seatbelts - $80 (will seperate)
Ignition barrel & locks + key - $100
PM me or reply here if youre keen on anything!
Cheers
Drivers door?
do you have the abs module thing
Which one are you after? the one that sits in the engine bay? PM me
PM'd >_<
Replied
Have you got the rear bumper? If so, is it in good condition? Price?
Sorry mate it's sold pending payment
recon the rear strut brace will fit a r34 coupe??
Dont think it will fit sorry
Still have the climate control unit available?
Sorry, also is the bootlid available?
This is also sold pending payment sorry!
Do you still have the boot lining available?
I can pick up from Sydney
yep, PM sent
Do you have the drivers door hinges? Condition/shutting smoothly?
yep, still have the hinges, drivers door shuts fine. PM me if interested
Drivers door?
Still have the door, but it's missing the switch, switch surround, and window motor & regulator. PM me if interested
Hey mate,
I transferred the funds for the steering wheel last night, Let me know when you receive it.
Cheers, Mark
cheers, PM sent
S2 steering wheel, rear hubs and handbrakes sold
Just wondering if you had any of the following
Feul Lid/Flap
Driver Side A Pillar Plastic
Standard Wheels
Thanks
yep, i've got the fuel flap lid and A pillar plastic. Pm me if interested
do you have the power window switch finisher? (drivers side)
Any parts left? I am after the passenger window switch finisher!
that little surround for the passenger side switch? i've still got it. Pm if interested :dry:
Exhaust, coilovers, stock SMIC sold
Are the calipers and rotors still available?
What condition are the rotors in? Any idea how much to mail adelaide?
Thanks!
hey, yep calipers and rotors still for sale. rotors are a bit worn, but still probably have some life. Calipers by themselves would be about $20~25 to adelaide
is the steering wheel available or sold yet?
yes it's sold
Pm sent
sorry, didnt get the PM?
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
