U guys might wanna consider changing da idle bearing and tensioner when da timing belt gets done cause u'd onli have to pay 4 labour once.....and its pretti important them to things get done....or u will b payin heapz for a rebuild if them things fail....
Got to agree with you there - as far as I'm concerned and for the cost of NSK bearings you should do the idler/tensioner bearings at 100000k's.
Don't forget guys that not all skylines have genuine k's on them - whenever I buy a car with rubber timing belt/s I change them straight away. You know what you've got then and no surprises.
I'm glad I do all this myself as I'm pretty blown away at the quoted prices!
Cheers
  • 2 months later...
My 94 R33 S1 GTS-T is coming up to 100K. Asked a few shops around SE Melbourne and they quoted me between 450-480 to do:
- oil (using castrol magnatec?!)
- filter
- timing belt
- spark plugs
I might ask other places for a price including:
- Coolant System Air Purge
- Fuel Filter
- Brake Fluid Flush & Bleed
Are the 3 things above necessary? What do ppl think about the quoted price?
personal i would go and do myself
oil filter
oil change
fuel filter
radiator fluid change (not really flushed, but same way you change the oil)
spark plugs if i knew the right size
the rest id have to try and trust a nissan dealership with
timing belt
brake bleed
power steering flush (do they do that?)
water pump
thermostat
all belts
maybe get some hoses replaced
clutch and gear box fluid
diff oil
have i missed anything??
also what does a nissan dealership do for a 100k service??
power steering flush... they can do them.. but bit fiddly. no need to really.
my GTR is nearly on 95km. i would replace all oils, ALL filters, belts if they need em. any pumps if u need them. if ur doin Tbelt. ill replace all idlers bearings and the weak bitch of an oil pump. that and do a complete fault check. that and Check and adjust tappets if u can on the GTR havent looked at it yet.
  • 9 months later...
Hi all!
I need to do 100k service and was wondering if anyone can tell me the pros/cons of getting a genuine nissan timing belt as opposed to a nismo or gates belt??? The price difference is enormous but I don't know if there is an actual physical/mechanical difference...???
Thanx...
nissan gen is a mighty find product that lasts well over 100K, so why pay more for something else that does the same job?
Timing belts dont break from excessive power or rev's... they break due to age/mechanical failure
Edited by simon-ae86
I agree... I'm just not sure if there is some sort of benefit in having an aftermarket one??? And why the hell are they so expensive - I can get gen nissan one for $60 but a nismo one is nearly $400 - WTF????? ;)
I would also recomend replacing the tensioner pulley studs aswell, i have heard of a few horror stories of peoples tensioner studs snapping and causing the valves to obviously hit the pistons, would be very pricey to fix so i will be getting mine done on my 90xxxkm service just to be safe.
this on RB engines.?
all the tensioner bolts ive pulled off are quite thick and look rather durable. not sure if RB have springs like toyotas but that tension spring needs looking at. but is part of the T-belt kit that should be replaced at the same time.
water pumps on RB common? keeping ur coolant in check, eg fresh and right type and ratio should keep it spinning longer. :)
Heres some evidence
http://www.skylinesaustralia.com/forums/in...howtopic=131579
Its also happened to a few guys on www.skylinesdownunder.com in n.z, so i will be getting mine replaced when i get the cambelt,waterpump and tensioners done just for peice of mind. Would rather spend a few bucks on new studs then having to rebuild my motor.
Ever been down to nissan to buy a genuine fuel filter lately?
Even those aftermarket ones aren't much cheaper.
my RYCO GTR fuel filter cost 40 at trade price.
and my RYCO S14a fuel filter cost 14 at trade price.
they dont look much different.? :wave:
Heres some evidence
hey buddy. wernt calling u a lier. but thanks for digging that up. was interesting. and i think ill change mine every so often too. :wave:
have a good one.
mark
  • 5 years later...
so i know this topic is old but ill figure i should ask in here rather then making a new thred....if anyone is still watching this one :/
so i took my r33 in to Xspeed in perth for a 100k service a while back and only had a budget of $1k .
their shop is constantly full of lines so safe to say they know what their doing (however rather expensive)
so the invoice i got back said the water pump was changed,
timing belt kit (the guy said that i still need a few belts done)
nissan oem coolant
and labour
i now have a list of things i need to work through, the most important of wich are:
--fan belts all u/s - require replacement but did not do due to budget constraints
--rocker cover gaskets leaking
--coolant condition poor- this one is interesting as the guy said my radiator needs to be sent away and cleaned as alot of the cooling tubes were cloged or something?
--and exhaust manifold missing 1 stud - he also said it needs to be taken off and machined flat again before putting in new studs...
now my issue is i dont know which one to do first?
does anyone have an oppinion on this or knowledge as to whats more important?
OR if any of these i can do myself with little danger of too much damage (not to experienced but always keen to give it a shot :P)
cheers if ur still reading hahah :D
  • 1 year later...
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
