Hey my heater is not working but my aircon is so im guessing its my heater core thats the problem.
how do i go about getting a new one eg where from and what part number is it?. if someone has had this problem before please help. Cheers jack
Dash, etc has to be removed to get to the heater assembly and the core itself BUT before going to all the trouble you should check that coolant is flowing through the core (ie check whether it's blocked, which usually happens because the coolant hasn't been maintained correctly). To do that you need to disconnect the heater hoses at the firewall and then use a garden hose (preferably with some sort of pressure attachment) to check that water flows through the core - effectively you'll be flushing the core (Note: you'll have to refill and bleed the cooling system after doing this). If water flows freely, the core is not the problem. Of course, this all assumes the core isn't leaking, but if that were the case, you'd notice the loss of coolant plus there'd be a musty smell inside the car and the carpet would be wet (also, even if that were the case, the heater should still actually work....).
It's also possible the heater isn't working because one or more of the airflow control motors has failed (GTS4 has similar digital climate system to GTR, as I understand it). Youy should also error check the system......do a search, someone will have described how to do it previously.
https://www.sau.com.au/forums/topic/274215-r32-heater-core/#findComment-4649160
Read this and do everything here before wasting your money on something that probably won't fix your problem: http://www.skylinesaustralia.com/forums/R3...rk-t236745.html and the climate control self-diagnosis in more detail: http://www.skylinesaustralia.com/forums/R3...old-t93814.html
https://www.sau.com.au/forums/topic/274215-r32-heater-core/#findComment-4649925
ร—
ร—
