easy, take the rb25 knock sensors and screw them into the provisions on the rb30 block
Im pretty sure there weren't any spots for them on the 30 block. Just trying to find out if there is another way around it without tapping 2 new threads in the side of my block (I dont get the car back till saturday so I'll check the block again then. Thanks for the idea tho :) )
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4650955
My personal experience as with many others was that the knock sensors were a straight swap. As far as I know both S1 and S2 RB30 blocks have the same provisions for knock sensors as RB20, 25 and 26. If for some reason yours is does not have these you may have to do something custom :)
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4651436
Look again.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4651529
Thanks heaps guys. I got the car back yesterday and pulled the inlet plenum off today. the spot for them on the rb20 is just below the head but on the 30 block the spot was there but they were not drilled at all, although there was holes drilled and tapped directly below the undrilled spots (if that makes any sense) im hoping it wont cause any problems having them half way down the block???
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4655806
Half way doen the block is fine - thats where mine are!! They do f**k all anyways.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4662491
Mine work very well in that location, consistent results when compared to the knock amp and headphones.
Cheers
Gary
The factory ECU will not retard the timing if it sensors detonation. From what I have seen it will switch between high and low octane maps based on knock feedback at low rpm high load. If it changes from high to low and it still continues to detonate there is nothing it will do to stop it. So in a sense they do f**k all.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4669900
I drilled and tapped the higher locations for my knock sensors, the thread pitch is 1/4 BPT by the way.
I run a PowerFC and rely very heavy on my knock sensors, so I wanted them to be as accurate as possible. Plus, it's very easy to drill, tap, and install.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4673145
did you actually notice any diffrences by mounting them in the higher positions??
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4674733
I could almost guarantee you that any location on the intake side of the block will work to the degree thats required for the factory ecu or PFC.
I have played extensively with knock sensor location on EJ25 block as I was experiencing spurious knock at a particular load and rpm point and found that moving the location of the sensor didn't help at all. Subarus are much more particluar with knock snesitvity than most other cars as they learn both advance and retard ignition.
https://www.sau.com.au/forums/topic/274233-knock-sensors/#findComment-4674933
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
