Guys after buying a trust style BOV recently from JJR i decided to fit her up and do my usual thing in posting the how to.
Here's the BOV i got witha universal adaptor (not needed)
Pic of the factory BOV with rubber pipe removed to the return line. It plumbs back to the intake, though i havnt bothered to plug it yet as im not aware of any reason it has to be.
Remove the factory BOV and you'll find a 1" hole approx into the manifold pipe note the extra vacuum line coz it could get in the way later. Mine went in fine though so its check twice cut once guys...
Overlay the factory BOV on some cardboard then the new one and trace the individual shapes in positions that will suit the layout without fouling the vac line or bolt heads etc. This way you make an adaptor plate that keeps the original stuff close at hand. Then take some 10mm alloy plate and drill, cut file and shave until its smooth and slick.
Here's mine before final filing of centre hole.
And after thats done fitted to BOV using supplied bolts.
Fit her back up with the gasket you took off the factory one and presto!
Run a new line from the manifold to the BOV (i used smaller Blue silicone line)
And enjoy the new toy...
You can see another part of why i aimed it away. Lines up with my vent in the CF hood nicely.
Defected no probs un bolt and return to stock instantly.
Thanks :P
  • Like 1
  • 4 years later...
If you want to line the BOV up with the factory recirc pipe (if you want to use it as a recirculating BOV), then you can drill and tap the factory crossover pipe. Obviously pull it off to do it
I did this with my Greddy Type RS rip off BOV before I went front facing plenum, worked a treat. Then if you want to go back to factory BOV, you can make/buy grub screws to screw into the crossover pipe (if you have drilled right through it). With some thread sealant you shouldnt have an issue
Not taking away from the original DIY, just an idea for people who want to go recirc. :)
Seriously, you cheaped out and bought a non genuine Greddy bov, then had to mod the crap out of it to fit. Why the hell didn't you just buy the bolt on Turbosmart Kompact plumb back for $170 and be done? Even grub screwing the bleed hole in the stock BOV would be smarter imo.
Plumb that sucker back or you will stall constantly, potentially causing an accident, not to mention the fouled spark plugs and black rear bar.
Was that aimed at me?
If so:
It was hardly 'mod the f**k out of it' by drilling and tapping 2 holes into the crossover pipe
it was recirculating
I only did it to check the BOV (which I was just borrowing at the time) worked fine.
I have a genuine RZ now, on custom cooler piping
I'm not sure what the bad reaction was for, It was merely another way to do it if you want to retain the recirc. It's not hard to drill and tap 2 holes in the crossover pipe..... I was just offering some advice
Not aimed at you Callan, Pete was duped into buying the crap bov and left it venting, then thought everyone should be doing it. He should have kept the stock one there, infact Nissan should have welded them in place imo.
My point was made today, as I sat behind an evo8 that flooded itself at the lights. As I was waiting for him to start it, I wondered if I would hear the all too familiar ssq noise, and I wasn't disappointed. :/
Modding your car for street cred and ruining it's drivability... I just don't get it.
All good, I was a bit confused but now that I re-read your original comment, it seems alot less aimed at me now lol, opps
Didn't even realise this was originally from 2009 lol. Thread revival and I got sucked into it. Thought someone would have done a DIY on this before
Alot of us have all been down the atmo BOV route with stock/MAF computer and once you see first hand how bad the car is with it, you dont keep it around for long :) We were all young and dumb once
Edited by 89CAL
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
