I think you would be more than lucky if there isnt ceramic dust inside the motor...
But anyway, you cant really tell @ idle. Obviously power/boost wont be the same... thats a given, but then why even attempt that and almost gaurantee a dead motor.
Just pull the dump off
well you have two turbos too worry about. but if it's stock then that seems reasonable. what give you the incline that they were damaged or were you just asking for future reference?
when it happens you will know about it. if you have the cash get some steel wheels put in there or upgrade. my 2c.
Symptoms are: no ability to make boost, and crappy running if you run the motor under the conditions in which it would have made boost. The working turbo will just push air backwards through the broken turbo's compressor, therefore no boost at the plenum. Idle and low throttle are fine as you are in vacuum.
just put some steal wheel turbos on a mates gtr he was on his way to adelaide and was all fine then went to over take a car and no boost, there was no bang clunk or anything just fell off. replaced turbos and checked comp and all good.
so they can let go at anytime you dont need to be giving it a hard time at all. we also never found the wheel thanks to a decat pipe.
From what i have gathered you dont have to be boosting hard thus creating massive heat and spinning the turbos at 1000000rpm for them to let go.
I guess with age, the more shaft play u get, if the exh wheel only scrapes or bites the housing this would be enough to send it flying out the back!?! That's why it's more common with the r32?!?
Its predominately heat, heat generated by shaft speed IMO.
Which is too much boost in the given application in simple terms.
eg. You are probably OK with 13-14psi for usual street duties
Circuit you wouldnt run anymore than 11-12psi... being extended laps is going to get a lot more heat in there
Hence its usually the rear turbo that lets go - hottest cyclinders are 5/6 in a stocker style setup.
Why do 5/6 get hotter? Is that why ppl richen up 6? Or does 6 run a little leaner than the others so its just compensating?
    • I like they don't raise their hands into the air when they shift their sequential boxes, seems to be a thing here in Australia lol...
    • I'm not normally one for posting random videos, but I thought we'd all appreciate the honesty about how broken our cars tend to be lol. Genuine skyline life here.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
