:P ty its actually measured off my R33 interior.
well. it only took a few arvos to weld up. could use some refineing and was relatively cheap.....the only catch is the seat. I had it lying around and its an actual car recliner, so it weighs as much as the rest of it combined. a generic seat of a lighter cheaper description would make it much more affordable.
Edited by boiracer
dude.. srsly??
what do you think polyphony have been doing for the last 5 years??
my money is that you'll forget all about forza before long..
working on other games.. As they stated in their interview.. Prologue and PSP GT and a couple of others.. You didnt think they been spending the last 5 years only working on this game?
well there is a light at the end of the tunnel. the game is currently in production.
there was some funny responses to this on GTPlanet. this was my favourite.
FOX NEWS BANNER APPEARS
This just in, a truck carrying all the Gran Turismo 5 discs has been loaded onto a plane to Yemen, along with a printer, a man wearing baggy underwear, and a guy wearing a shoe with a match.
yeah i been waiting for them to put a r33 gts-t in it too. do they have the r32 gts-t in the earlier ones? from memory they do. sif put that gutless piece of aids in and not the 33
I'm not sure. I haven't played GT since GT2, have been playing Forza.
In Forza 3 I had to convert a R33 GTR to RWD to make it like a GTST but it still keeps the RB26 so it's not a real GTST of course.
in gt4 you could get an r32 gts-t m spec, though if i remember you could only get the r33 gts and not the gts-t.
i will be pretty sad if theres no r33 gts-t. but you would think after taking 20 light years to make they would have all the nissan skyline's down pat. same goes for the 180sx.
Anyone know for sure if the R33 GTST is back in or not?
I'm tired of pulling out GT2 and the OLD Playstaion to relive my old car :)
I suppose we'll find out in about a months time.
pft, your doing it like a sucker
forza 3 has all the cars....
pretty sure one of the guys at harvey norman here has one. needless to say he works in the computer section. and he drives a supra, which isn't suprising since a hell of a lot of IT nerds drive imports. pretty much never see one in a commodore. it's usually either lancers or imports.
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
