Bathurst is the only thing on that list anyone'd care about
i think the wants and needs of australian fans would have been relatively insignificant compared to that of asia/europe/america.
im pretty sure they have those POS official V8 supercars games.. go get one of those lol
Im kinda dissapointed in the car list :dry:
Way to much emphasis on jap shopping trollies, it is good to see more yank cars than previous games though, just hope the sound is better than the previous 4 versions though.
31 GTS-R is a nice inclusion, but I would like to see some of the more less common yank cars like an oldsmobile 4-4-2 or a 1963 falcon sprint but either way I am very suprised the BOSS 302 mustang wasnt included.
Oh well, Ill still buy it lol
egg zackery
the realitively small number of Australian (or elsewhere) gamers that care to see Bathurst included doesn't warrant the massive amount of time and expense
Bathurst is loved internationally, remember the group A days where heaps of international teams turned up, It was part of the World Group A touring car championship
and as far as the actual track goes, it is an extremely technical and tricky track, so even though people might not know the track, i think a lot of people would like racing on it.
i'm glad the xr8 v8 supercar is still there. i really like racing it.
No bathurst?
No Lakeside?
No early RX Mazdas?
Pfft - FAIL
Kind of expecting Bathurst
but hey i will be kept busy with "Nürburgring" for a while and i am sure they will include Bathurst may be as an update later down the Track at some point
The track list looks a little small when compare to the ones GT4 had but I guess the track editor will make up for that. Was a bit surprised that the mk4 supra isn't premium since all the other major japanese cars are. Either way, not long to go now! :P
Hahaha they got the R32 GTSt but no R33 GTSt!
absolute spewing. ah well in gt4 the r32 gts-t was probably my most used car in the game. and the amount of silvias and skylines they have in the game would keep me busy for a good 3 years haha, not to mention the other 950 cars!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
