Ahk cool, I knew the car you meant, but I didnt see it in the list, Was in previous versions of GT though...so might be lucky and they will stick it in there.
or just "stage 5 turbo" the road car lol
I hope so, it was in GT1&2 I'm pretty sure... those games are to blame for turning me into a skyline head in the first place... HKS drag 33 was hilarious to punt... also have a major soft spot for RUF Porsches, had some silly modded one that would decimate all my mates cars... alas my budget to actually own those cars in real life only extends to a 15yr old GTR... maybe I'll get back into RUF tuned Porsches in GT5 and in 15 years time I'll actually be able to afford one lol
i remember one of the early GT games where you could win/buy a proper drag car. think it was a funny car type thing or was it a full dragster? i can't remember, but anywho, that thing was funny to try and race around tracks with. blast it down the straights and then have to slow right down for corners, lol
Yeah the glitch was cool. turn rear downforce up to full, turn the front downforce down to the lowest setting. at about 350kmh it would do a wheelstand and the speed would skyrocket.
Pretty sure there was a drag car in one of the earlier games that wasn't the hks 33.
If I remember correctly there were 2 HKS drag cars, the R33 and a 180SX....
R33
180SX
it was at the Eb games in Vic park centre W.A
I even asked him if he was sure coz i saw 25th on the site and he said yeah they got a last min thingy. Maybe he was just bullshiting...
probably not bullshitting, just an idiot who saw an email saying "next thursday" and thought "the next thrusday is tomorrow (well today now) so that must be when the game is being released"
EB have a bonus for pre ordering the standard edition that they updated today. Before I believe you didn't get anything, now if you pre order the standard edition you get all 6 of the stealth cars from the signature edition.
anyone wondering about the game should read this. 40 minute install time is going to suck. i'll just start installing it the moment i get home and then it should be done by the time i finish dinner
http://www.gtplanet.net/forum/showthread.php?t=132738
^ lucky I've got a heap of HDD space, then
Its still 25th of November on ebgames.com.au - they wouldnt do a last minute release like that... a last minute delay sounds more believable! :)
pre-ordered a standard copy from JB Hi-Fi last night, and the woman at the check out mentioned they were currently embargoed- which means they're in the country ready to go. probably under military guard!
my receipt confirms release date is 25/11/10 :D
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
