Have you done like the wind ?> The final one ?
Basically, Buy a Corvette ZR1 or whatever the are from CHEV.
take it to GT AUTO
Perform racing modifications.
This should give you pretty much all the expensive shit in the tuning show (weight reduction etc etc)
Now go and fully tune the engine as far as it can go.
Buy racing softs.
You should now be able to win most races.
Win the "like the wind challenge"
You with the Toyota Minolta 88C-V, Give this car the biggest turbo upgrade and racing soft tyres.
You now have a car to beat any cup it is eligible for.
does rebuilding the engine and chassis actually achieve anything ?
I don't want to do a full 6 hours of testing at the ring to determine this.
beaten all races bar the bottom 4 of the enduro's and the Formula GT world championship.
rebuilding an engine will see you get an increase of hp (takes it back to what it was stock), so if you have a car that you have used a lot and it is down on power compared to when you first bought it and an oil change still doesn't take it back to full original power then a rebuild will.
don't know about the chassis one though.
take it to GT AUTO
Buy racing softs.
Well didnt work....will have to slug it out to 5mil credits the old fasioned way
Yeah Zebra,
What exact car did you buy.
If they are catching you make sure you play with gear ratio's depending on the track.
I found I could go a lot closer on Daytona Infield circuit and then of course open it right up for Indy.
It wasn't a struggle, it should be a pretty easy clean sweep for you.
the prob I have is getting past the cars through the infield, no where to pass/or you just get bumped off....it shits me that there is no quali...fkn over starting in 7th all the time
Rolling starts also shit me to tears
Im almost to 20mil thanks to remote bspec haha
hahaha, yeah thanks for that. i log in every week or so and retrieve the prize money i've gotten thanks to you and a few others. if i have time i run a few races to pay you back a bit too.
zebra i sent you a friend request on PSN ages ago. i could've earnt you a heap of money over the past few months had you accepted, LOL
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
