Hi everybody ,
Just noticed the other day that my turbo has started to whistle when on boost. It sounds like an air leak of some sort, coming through the intercooler or something, i'm really not too sure. The performance hasn't really differed. It still makes a full 12 pounds and holds it well, it's just making a whistling sounds the whole way through. As such, i'm hoping to god that the turbo isn't rooted.
Can anyone give me any ideas as to what it could be? I'm hoping it's just an exhaust gasket or something, but i'm not sure.
The car has a return pipe intercooler, turbo tech boost controller, 12 psi, pod filter etc.
Any help would be appreciated.
Regards,
Astro.
https://www.sau.com.au/forums/topic/274931-turbo-whistling/
My car made this noise also when one of the hoses popped off my boost tap. So i'd say it's definately a cut in a vacuum hose or a hose that has popped off.
Hi everybody ,
Regards,
Astro.
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4659206
Been running 11-12 psi for a few months now with no dramas. I put a pod filter on it a while back and it started to spike to 13-14psi when the foot was planted, so i've stopped doing that and have been pretty much babying it ever since, rarely going past 10psi. The whistling only started happening about a week or two ago, no change in performance, just the noise, which makes me think the turbo isn't rooted, and it's just an air leak somewhere. Thoughts?
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4659646
Hey Mate,
My turbo started doing the same thing about 6 months ago. Started whistling really loud but still making boost. I thought my turbo was stuffed but it ended up being the bolts.
Check all the bolts around the turbo. The ones that bolt it onto the manifold. After I tightened the 4 bolts that connect the turbo to the manifold the whistling went away and hasn’t come back. Just make sure they are all really tight.
Hope that helps ya :D
Maybe also check the dump pipe bolts, just make sure everything is nice and tight.
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4659689
Hey Mate,
Hope that helps ya :)
lol i cant believe that happened to you too!
one of my mates r33 had the same issue, he took it to a few places and no one knew what was wrong and said your turbo is gone (wont mention workshops) he even went out and got a second hand stocker to replace it. i ended up pulling it apart and found that all 4 bolts on the flange were lose! so it was an easy fix.
but it does sound like an air leak/whistle or like your turbo is about to shit it self, but it still boosted..
the cause of the problem is that if your exhaust/dump pipe doesn't have brackets holding it steady, the weight of the exhaust will rattle it lose. common cause with aftermarket dump pipes.
-alex
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4659977
basically this is already answered
but its usually a leak between turbo and exhaust manifold and/or a leak between turbo and dump pipe. Gaskets may need replacing, or it's just the bolts have come loose.
I've had it happen twice before (2 skylines) and fixed it twice. Not a massive deal. And it sounds much like this.
hope this helps.
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4661138
Mine has been doing this also.... I have a jjr dump/front and turbo tech boost controller @ 12 psi. Makes this whistle occasionally at high boost. will check my bolts an gaskets. i had to tighten them up when installin the dump pipe so maybe coming loose again. But have recently noticed it after installin my trust fmic.
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4661451
Hi everybody ,
Regards,
Astro.
Its definetly one of the hoses leaking....i have a r32gtst after upping the boost to 14psi i heard this whistling noise...i thought turbo was gonna blow and i got advice of my mate and he rekoned it was intercooler piping
I started tightning down the clamps and sure enough it was a bit loose.....i tightened almost all of them and now no more whistle on 14psi and boost comes on quicker and much harder
Go through all your clamps and tighten them down as much as you can and also inspect hoses
Since you are running 12psi it cannot be the turbo because standard skyline turbos can handle 12psi all day everyday...i am running 14psi which is right on the edge not good lol i should run 12psi to allow space for boost spikes but since i use an electronic boost controller it eliminates boost spikes
Give it a go and lemme know if it is solved
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4663366
Not entirely true..
to clarify my statement my mate that i got advice of has run 12 psi everyday for 4 years and he hasnt had a single issue with it...and what i meant by 14psi on the edge was that after 14psi the ceramic exhaust wheel can come off....you can boost more than 14psi but what i meant by edge is that 14psi should the maximum for the turbos health and your wallets wealth
My other mate had boosted his 32gtst to 14psi and was running all day everyday but he didnt take boost spike into account and the turbo is gone now...he had massive spikes and didnt bother changing to electronic boost controller and just used the tap....
You can run 14psi including or excluding boost creeps....variables always have to be taken into account....i recommend electronic boost controllers
so far my 14psi is going good....but the thing is i am used to the power now....that the thing after driving around with power upgrades...after 2 weeks its like normal...lol
Aye i need you guys honest opinion on this.....i wana get more power on my rb20det so what turbo u rekon i should get? r33gtst standard, gcg high flow, hks 2530, gt28rs, or the t70 turbo on ebay lol
Cheerz
Mosh
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4665376
10-12psi is generally regarded as the safe limit for an R33 turbo.. If you run 14psi on the street and only do the odd traffic light grand prix then sure it'll probably handle it but try half a dozen laps on a track and you'll be limping back to the pits to lick your wounds.
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4665431
aha I had some whistling, after 3 loose hoseclamps, replacing the hose between crossover pipe and throttle body and its clamps, adjusting the clamps so the hose dosen't have a tendency to want to slide off over 14 psi, replacing the V-band clamp and turbo gasket, I have now touch wood successfully eliminated all whistling from the car other than the induction noise. :D
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4665450
Mate iam not sure about r33 turbos....i was refering to r32gtst turbo......and yea ur prolly right since 14psi is my max for daily driving, going on tracks with 14psi is definetly a no no
As i said before variables always have to be taken into account...so for tracks i would prolly run 12psi
By the way will r33 turbo be a good upgrade for my rb20? how much power diff?
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-4665670
  • 7 months later...
I had a similar issue.. turned out the turbo's bearings were shot. I could hear the whine at idle especially.. Glad i have had it rebuilt now.
Hi, ive just started to hear a whistling sound, or almost a really high pitched ZZZZZZZZZ noise coming from somewhere though not that loud.. yet, hopefully one of the turbo gaskets/manifold joins or something simple.
Anyway i was interested, when you say you got it rebuilt, did you get your stock turbo "highflowed"? if so what is the deal, do they replace it with steel turbines and was it expensive? cheers.
https://www.sau.com.au/forums/topic/274931-turbo-whistling/#findComment-5043349
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
