  • Replies 443
times ok for me, gives Lee about an hour of bragging rights, any mods been done to the holden?
Yeah times fine by me too Cara :thanks:
Ha Ha so true....should run your beast off spring pressure to make things interesting :D .
My time suits me Cara :D
Still undecided if its the Stagea or the 33 going on as yet.
... on another note, fitted the 33 type M bar today :(
TypeM front bars aint going to get you more Jiggawatts on the dyno but :thanks:
im gonna have to bail on this one..... my car is running way to rich to even be putting down any power and probably just blow fireballs... occupation health and safety right there... wont be able to get the funds for tune before then either
Nothing serious, just LS1 edit, exhaust, extractors and custom air intake.
The edit was done long before we got it and it hasnt had a tune or anything latley so im not expecting to pull crazy numbers.
... on another note, fitted the 33 type M bar today :)
type m ftw!
and good to see i made it on to the entrants list :( time is fine too. cant wait to see what it pulls with the manual in it
9.00am Cara - MissR34 - CONFIRMED
9.15am Krishy - CONFIRMED
9.30am Wayne - Weezy - CONFIRMED
9.45am Ruby - CONFIRMED
10.00am Lee - RB25DETS2 - CONFIRMED
10.15am Pat - JET30 - CONFIRMED
10.30am Chad - DSTROY - CONFIRMED
10.45am Craig - PREISS - CONFIRMED
11.00 am Adrian - 180OR200 - CONFIRMED
11.15am Penny - ontheranch
11.30am Anthony - love my 32 - CONFIRMED
11.45am Marko - SkyHi_33 - CONFIRMED
12.00pm Brenden - MrRS4
12.15pm Vu - typevu - CONFIRMED
12.30pm LUNCH BREAK
1.00pm Ben - Dohmar - CONFIRMED
1.15pm Tony - Foolboost
1.30pm Ahmed - MEDMAN2DAMAX
1.45pm Lex - youwish - CONFIRMED
2.00pm Luke - enr034
2.15pm Michael - Brezza
2.30pm Kye -imports13
2.45pm David - writeoff
3.00pm Ben - grim32 - CONFIRMED
3.15pm Danai - ovrtym33 - CONFIRMED
3.30pm Shaun - evil34
JK has got his work cut out for him :)
Umm...I've just started getting hours on Saturday again >_> would it be ok if I swapped to something earlier? Something before 11am if possible
Pat i can swap you my slot if you want mate....we just have to let Cara know and as long as she is happy i am more then happy to give you my time slot mate
i need everyone to please confirm with me that the time allocated is good for them, thanks
I'm happy with my time slot.
I was the first person to do so.
Are we just paying John Keen on the day or do we pay you beforehand Cara?
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
