what are you trying to say krishy???
also be highest power used from the 2 runs
krishy is just begging for u to shove a rocket up his bum and set it on fire
i know who the first man on the moon was
krishneel armstrong
haha
-D
  • Replies 443
Kye you don't have to come earlier if you don't want to or can't for any reason, but you should try and come as early as you can :rofl:
Translated : Pete advises that if you are suffering from premature ejaculation, you can get a desensitizing spray, and if you cant get it up, he can get u some viagra, but in his own personal experience, he would prefer to get the deed over and done with as quickly as possible, which generally means taking the viagra as well as the spray (Its great living in a capitalist country with supply and demand) :banana:
-D
Numerous pages have advised that there is no a reserve list (yes the spots are full).
Numerous pages also advise to contact Cara for a spot on the reserve list. :)
If anyone wishes to help promote the event, copy and paste this code into your signature:
[url="http://www.skylinesaustralia.com/forums/official-Sausa-Dyno-D-t275144.html"][img=http://i114.photobucket.com/albums/n273/Damo_s13/SAUSig2-1.jpg][/url]
Looks like I'll be there for LOTS of photos and a snag or two
see if we can get some decent shots of the cars ...lol ...SAU needs hot models for event photo shoots..loland Im not talking about GTR VSPEC2 models..lol
Edited by sapphiregraphics
For a minute there troy i thought u were offering to get urself into a mankini, borat style!
-D
-D
yeah that would be a site , even I wouldnt want to see that...lol
but I have a leopard skin mankini ,ass floss model...VERY HOT..and pulls the chicks and police as well..lol
i think with what is lined up already for the day, we dont need to be worrying about having models and what not there
+1
The only curves I'll be looking at will be on the cars. The day is going to be awesome! Glad to be a part of it. :rofl:
I'll be cheating a bit Cara ... I wanna get John to tune the Stag a bit before the day, as I've only done oil changes etc in the past 20,000kms.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
