very well organised event and was happy to catch up with a few people....sorry i had to bale really early as i was in a very very bad state.....but good day all around.....so has anyone posted up the whole days power figures???
Oh you awake now Krishy? :)
  • Replies 443
ah dont even go there Damo lol....man oh man what a hectick friday night it was....i think i had mentioned earlier that i might just be in a very bad state...which it ended up being lol....my insides are hating me
thanks to all who organised it!
was a fantastic day!
i am really happy with my consistent 240rwkw, hopefully by the time the next dyno day comes around i can get the car to climb over the 300rwkw mark.
i'll have to remember to wash the car next meet!
Brezza
i wanna know how i lost 10kw by adding a new fuel pump
Running richer due to the increase in flow. Thats half my problem too. Do you have an adjustable FPR?
it was the same dyno each time its been tuned....174.5 with n/a pump and reg.....then 150 with 2nd hand 040 and vlt reg....then 140.1 with new 040......i just dont get it...i might hook up my n/a reg and see how that goes for the time being..until i can afford a malpassi blacktop and a remap
I lost 15kw by replacing coilpacks. Differences between dyno I guess - it better be and not be something wrong with the car haha
I dont think that dyno read low Vu.....i made 214 and previously the best was 211....but i am eager to find out as to how the f**k can you loose 15kw by getting better coilpacks???? i gained power by getting splitfires
that animal being Pete, i swear he ate at least 6 sausages with bread
didnt he say he was going home to eat his wifes lamb too....lol ? hollow leg pete ?
sorry nugz I only have this shot of your car I think
what coilpacks are you running now Vu
i think hes running yellow jackets like me, i got 189.6 rwkw on 10psi (might have spiked higher, no readout on dyno chart). last dyno run i had 173 on 13psi without coilpacks or dump pipe.
what plug gaps you running vu?
my dyno chart is once again flat mid way... needs a good tune, think there's a few kw in there somewhere too, have a feeling it might crack 200 on 12psi.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
