i menat in au3. sorry.
Yeah and doug and myself both have about double his power so still correct. Apparently he was running 6 degrees of camber :D
The coolest part was that he hadn't even widened the body with flares or anything, just had some 13 inch rims with some sticky rubber.
  • Replies 167
That was the blue one parked next to me up the top of the pits. I spoke to him late in the day and he said he'd run a 1:39. I dunno about his power but his suspension setup is mint and he was tweaking it all day.
What he lacks in outright power he'd certiainly make up in corner speed, 70kW does sound low though.
It definitely looked like a well prepped car, and sounded great too. Goes to show that suspension setup and talent are they key!
Pink180: Was yours the silver Sil80? Looked really nice mate, sorry to hear it's damaged.
Side note: I checked my intake pipe and it has a hose clamp on it so it must be a standard T25.
A lot of people were spearing off the track on the sweeper on Saturday, Russ looked to have a wild ride in front of me in the second session!
I enjoyed it so much that I went off in the last session too! haha
I had an absolute blast with you guys out there on Saturday. It was my first real grip day as im usually drifting instead haha... The WRX guys did a fantastic effort running the day, one of the smoothest track days i have ever been to.
Cant wait to get back out there just got to find a new shell after i put the car into the wall on Sunday :)
Yeah that sucks man. I crashed mine last drift day. Hope you get it back out there.
Yeh thats the one... Ive got another shell on the way so it should be back out in a few weeks just more $$$$$.
Your car looked awesome too mate! I remember back in the day when you had the meisters on it they were soo crazy back then!
Edited by pink180
Thanks mate, shame I didn't get to clean it up a bit before I came but it's getting there. How times change hey?! Now everyone has massive rims with big offset... :cool: Youd idn't damage your TE's did you?
Bris: Haha nice mate!
Thankfully no. I had borrowed some rims for the back off a mate, they copped some heavy scratches so it looks like ive bought myself some more rims!
Hello fellow Nissan lovers, my first time on this forum - joined just before the track day.
Thanks to all that had a part in organising and running the event. I was messing about with my suspension during the day so it really helped to have as many runs as we did. I was progressively getting quicker and did my best lap time on my last run. (1:34.7)
I was impressed by how BBGTR gets out of the corners. I was behind him during a session and he was pulling about 20m on me as we put the power down.
Hey Paul, I did my best time in the last run as well, but still recall seeing your car disappearing into the distance down the straight. :D
btw I recall doing two super sprints but can't see both in the results. Is s21 the combined runs or was only one timed?
Hi Paul,
Great time, I didn't do the supersprints - perhaps I should of as the track was getting faster all day!! I was having a few sideways moments around the boobs with power oversteer - apart from that the car seemed to behave itself.
Hope to see you at more events, need a few more R32's to play with!
Cheers
Andrew
Yeah its a totally diffrent car. Still wants to lock the rears but apart from that the mid corner and exit grip is higher than anything ive ever driven. It actually feels like it gets out of corners quicker than a GTR now. Soooo happy.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
