  • 4 weeks later...
there's a 2002 R34 GTR V-Spec II im considering atm. Im going to inspect it in the next few days. At this point in time i have only seen photo's. But the bonnet does not have the vent which i thought V-spec II have? When I'd asked him about it he said that the cbf bonnet with the vent is a added option? Am i missing something in the 2002 model? The seats are aftermarket aswell so couldn't even tell if the orignals were the darker colour. Either its a v-spec I with a VII badge or for some stupid reason someone decided to change the orginal bonnet?
Hey man, post the link as there is a dodgy trader on carsales.com
all 2002 vs2's have the cf bonnet with naca duct.
If it doesn't someone's switched it or it's not a vs2.
a better idea is to get the vin numbers and pass it all through FAST to see if it's the real deal.
This bumper with the gills on the left hand side, was that an optional extra?
yes it was a optional extra it was for an oil cooler mounted in the left hand guard you got the little air guide peice that mounted on your standard front bar and a vent that went on the side you had to cut out a hole and of course you got a oil cooler
Ah ok - cool, very helpful. Thanks.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
