I have too much stuff in my garage and house that I don't need.
Everything is in used condition unless stated otherwise.
Melbourne pickup is preferred but can send smaller items interstate if postage is agreed.
**I'm trying to post pics. atm but they're not uploading properly so please contact me and I'll send them.
If interested pm or [email protected]
Thanks for looking.
engine
turbosmart external wastegate pro-gate 45 $450
custom intercooler pipe with r33 gtr nissan bov 14483-05U00 $70
k&n mushroom filter RX-3900-1 + filter adaptor for subaru $60
justjap coolingpro intercooler 2.5" 600x300x76 (new) $120
r33 gtst front engine cross member $60
r34 gtst air box + intake pipe + recirculation pipe (no snorkel) $120
r33 gtst oem side mount intercooler + piping $100
nismo 6 x 740cc injectors 16600-RR544 (side-feed for r33 rb25/sr20) $500
nismo fuel pressure regulator (new) 22670-RR580 $160
nismo mounting bushes 11320-RSR40 (gearbox) 2 x 11220-RSR40 (engine) (new) $450
nismo thermostat 21200-RS580 (new) $160
r33 gtst rb25det racepace engine, arias forged pistons, gtr rods, n1 water/oil pumps, nismo bearings, machined/honed/prepped (never installed since rebuild) (excellent) $4000
r33 gtst gearbox + cross member $1100
r33 gtst/r34 gtt high energy 7.5 litre capacity sump (baffled for circuit use) (new) $700
r34 gts rear wheel hubs + brakes $150
r34 gts rear cradle $200
r34 gts lsd diff + driveshafts $200
suspension
r34 gtt dms blue 50mm coilover suspension (height/bump/rebound adjustable) (needs coilover tops) $2000
r34 gtt tein ra coilover suspension 10kg front/8kg rear + spare 4kg and 5kg rear springs + custom dustboots (aluminum body) (height/combined bump/rebound adjustable) (excellent) $2500
r33 gtst/r34 gtt 20mm front + 24mm rear adjustable whiteline swaybars (painted black) $350
r33/r34 rear camber + toe pillow ball arms + dust boots (painted black) $150
electrical
hks speed limit defencer type I with packaging 4502-RA002 (remove oem 180km/h limit r32/r33/r34/s13 and other makes) $170
r33 gtst ecu/engine loom $30
r33 gtst auto dash 47000km $30
r34 gtr v-spec rear computers + yaw sensor (unknown working conditon) $80
body
r34 gtr bonnet + hinges + latch (has minor damage but repairable) $500
r34 gtr tail-lights white (excellent) $400
r31 sedan head-lights (left + right) $50
https://www.sau.com.au/forums/topic/275509-r33-gtstr34-gtt-parts-for-sale/
can you send pics to [email protected] of:
1. custom intercooler pipe with r33 gtr nissan bov 14483-05U00 $70
2. r33 gtst/r34 gtt 20mm front + 24mm rear adjustable whiteline swaybars (painted black) $350
is price neg? where abouts melb?
  • 5 months later...
  • 4 weeks later...
hey buddy, cant PM at this time..
just wondering what condition the r33 gearbox is? any crunching? smooth changes? any problems?
also, what are the nismo engine mounts off? are you willing to seperate the nismo gearbox mount?
im very keen. located in sydney but im heading to melbourne in a few days.. PM me your number and ill SMS you. cheers
  • 1 month later...
  • 3 weeks later...
is the r34 gt-t air box the same size as the r33 gts-t air box? only really after the bottom part.. Also, dont suppose the cooling pro FMIC is the return flow style with the piping is it?
  • 2 years later...
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
